| diyAudio Sponsor | ||
I think I got over my head in coming up with this-
This is a hodge podge of techniques found in many posts, including Thorsten's... C1 is the ultra-path cap, C2 is a decoupling cap together with C3 bypass cap. R1 is the pentode driver cathode resistor, R2 forms a voltage divider to pentode screen, R3 is the cathode resistor for the 2A3. R4 is the plate load for the pentode driver, and R5 is the voltage dropping resistor. I need a sanity check on the topology before I calculate the actual values. As usual, the forum's help will be much appreciated. |
#2 |
Arnold,
Your circuit looks identical to one published by Thorsten: http://www.diyaudio.com/forums/attac...amp=1081427749 He wrote a tutorial showing how to calculate all the component values here: Calculating DC coupled Single Ended Valve Amplifiers - Part #1 Hope this helps. pm
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman |
#3 |
That's it!
Thanks! |
| Sanity Check ..... please | Lostcause | Digital Source | 0 | 16th October 2008 06:19 PM |
| XO sanity check for newbie | avizandum | Multi-Way | 2 | 30th December 2007 08:29 PM |
| Concertina sanity check | PeteN | Tubes / Valves | 12 | 27th June 2007 03:54 PM |
| pentode driver sanity check - before i build | zobsky | Tubes / Valves | 5 | 5th July 2006 02:55 PM |
| Sanity check | planet10 | Multi-Way | 14 | 7th March 2004 10:15 PM |
| Page generated in 0.06926 seconds (70.02% PHP - 29.98% MySQL) with 10 queries |
