| diyAudio Sponsor | ||
Hi all. I have been designing a little direct coupled 12B4A amplifier this evening that I plan on using with a Fostex BLH. Since I am using direct coupling the bypass cap on the output stage cathode has to have a fairly high voltage rating. I would prefer to use a MKP cap there but obviously I don't want to use more capacitance than is needed to get the job done due to cost and size restrictions. Unfortunately I'm drawing a blank on how to calculate the minimum size needed to bypass the 12B4A cathode. I went through the Navy electronics documents but I could not find the precise info I need. Would someone be kind enough to give me a hand?
Gavin |
#2 |
It's on page 79 in Morgan Jones. Basic answer is to use the standard equation for finding the corner frequency.
F = 1/(2 * pi * C * R) Into the resistance variable, you need to consider two resistances in parallel. These are Rk and (Ra + ra)/(mu + 1) |
#3 |
Do you mean Rk || (Ra + rp)/(mu + 1)?
Be sure your foil hat has a good low impedance ground. |
#4 |
That is what I understand MJ to be saying.
#5 |
...then take resulting capacitance and double it for good measure in practise
#6 | |
C=1/(2 pi F R) and R=(Ra+ra)/(mu+1) In this case is Ra the DCR of the primary of the Output transformer? I believe that ra is the plate resistance at the operating points that I have chosen. Correct?
Gavin |
#8 | |
R= Rk II ((Ri+Ra)/(mu+1)) where Rk is cathode resistor Ri is internal R of toob Ra is load of toob (impedance (nor DCR) of OPT primary) mu ........is mu
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#9 |
Been wondering about this myself with my Loftin-White. Circuit calls for 100uf. Tried several electrolytics for 2A3 cathode bypass & didn't like the sound of any of them. Requires a 250V rating, so pickins' are slim.
Now using a 30uf Solen (for max size reasons) to bypass 2.4K ohm. Overall sound is better. Used the simple formula: 1/ 6.28*F*R to come up with 30uf = 3db@ 2.2hz, but guess there's more to it than that. Please check my math using specs for Sovtek 2A3: Ra 3K ra 1K mu 6.5 4K / 7.5 = 533 533 II 2400 = 436 1/ 6.28*5*436= 73uf Used 5hz as this seems to be a good point to shoot for in a single ended amp. From this calculation, I should be using around 73uf? |
| 2A3 without cathode bypass cap??? | papparazzi | Tubes / Valves | 13 | 25th May 2008 04:06 PM |
| Need recommendation for cathode bypass cap | andy2 | Tubes / Valves | 12 | 15th February 2006 07:09 PM |
| Which BG cap best suited for cathode bypass? | reaction | Tubes / Valves | 10 | 25th April 2005 07:43 AM |
| Cathode bypass cap ? | woody | Tubes / Valves | 2 | 19th May 2002 05:53 AM |
| Best Cathode Bypass Cap | Mohan Varkey | Parts | 4 | 6th May 2002 08:59 PM |
| Page generated in 0.10115 seconds (79.37% PHP - 20.63% MySQL) with 10 queries |
