diyAudio Sponsor
Old 10th April 2007, 03:44 PM   #1
VR2ZXP is offline VR2ZXP  Hong Kong
Default Transfromer value of this 300B circuit
Hi all, How are you? May I have the value of the interstage and final stage transformers of this circuit which came from SunAudio in Japan?
Please teach, thanks very much!
Old 10th April 2007, 04:25 PM   #2
Tweeker is offline Tweeker  United States
They dont give out the specifications of their propriety transformers. In any case, when selecting an output transformer for SE, its a tradeoff between power output and distortion. Generally a higher impedance output transformer gives less power and less distortion.
The Western Electric Datasheet gives quite a few operating points.
Be sure your foil hat has a good low impedance ground.
Old 10th April 2007, 05:27 PM   #3
Hi Tweeker, thanks for gave me the datasheet. I tried to attach the original circuit here but it cannot be displayed. It should a 6SN7 in parallel for the input stage and connecting to a pair of 300B for PP by a interstage transformer.
Circuit :
http://www.diyaudio.com/forums/showt...?postid=539568
Old 10th April 2007, 06:15 PM   #4
phn is offline phn  Sweden
phn's Avatar
For 6SN7 in parallel, 10K should do, figuring I'm right about the impedance of the 6SN7. The Tamura B-5001/6001 or B-5006/6006 should work. An input step-up trafo might be in place as well.
Old 10th April 2007, 09:45 PM   #5
Ah, I didnt know which Sun Audio you were building, and I assumed it was one of the SE models.
Given the lack of feedback around the 300Bs, and the cancellation of 2nd harmonic in push-pull, Id suggest a relatively high load impedance. 3rd order distortion drops dramatically with higher load and will be the dominant type. See fig 9 in WE datasheet. From what I can tell Tamura only offers 3.5K and 5K PP OPTs off the shelf, so with that vendor Id go 5K. Each tube sees about half this in class A.
SE 300B Integrated Amp: Help choose circuit design xenithon Tubes / Valves 18 15th April 2011 05:33 AM
300b Circuit Mod. ttray321 Tubes / Valves 11 13th May 2005 08:20 AM
Fixed Bias Circuit for 300B LeoJar Tubes / Valves 9 13th February 2005 12:58 AM
QuestionSSS about 300B circuit mcdoong Tubes / Valves 15 26th February 2003 05:51 AM
How to test Transfromer? Cephas Parts 2 10th February 2003 04:44 AM
Page generated in 0.09466 seconds (72.77% PHP - 27.23% MySQL) with 11 queries
