Hi Guys, presently my Jadis Orchestra right channel is giving me some distorted sounds only at certain frequencies. I had tried swopping the right set of tubes with the left set but still get the distorted sound at the right channel. (including swoping speakers)The right channel sounds slightly softer and the distorted sound only comes out from the tweeter. I am suspecting the passive components is giving me some problems, can someone please give me some advice? Thanks in advance.
#2 |
Are you using a preamp, did you swap the power amp input cables? The CD player outputs (if that's what you use as a source) as well? Is the sound in the lower octaves without distortion? Is it the same level as the left channel?
I know, questions, questions... Jan Didden |
#3 | |
| ppi pc2150 distorted right channel | 67elcamino | Car Audio | 16 | 29th August 2009 06:46 AM |
| Distorted left channel - Marantz 2385 | jblmar | Solid State | 2 | 27th March 2009 05:04 PM |
| Distorted left channel Proton 520 Amp | allank | Solid State | 1 | 13th September 2006 01:41 PM |
| eq for low freq channel | hakalugi | Subwoofers | 9 | 11th August 2005 08:59 PM |
| put my pre-amp together and now the left channel is playing distorted :( | elizard | Solid State | 21 | 4th April 2003 06:23 AM |
