| diyAudio Sponsor | ||
Well, I thought I had found a killer deal at the surplus store on some 150VA 240VAC-120VAC step down transformers to use for tube PS's. On bringing them home I found I had purchased some autoformers
![]() So, do they have any value as PS chokes? Is there an easy way to roughly estimate inductance without purchasing a meter?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 | ||
You might possibly be able to take the cores apart and restack with a gap. That way, they might be useful as ripple chokes. |
#3 |
Hi Leadbelly,
First thing you'll need to do then is restack the laminations into a gapped core to handle the DC. Gap size depends on their VA size. 150VA would probably need .6-1mm gap. Cheers! |
#4 |
This requires at least a DVM, but one crude way is to check its impedance of a 60hz (or other) signal, best to use real, fused stepdown/isolation xfmr as source (Im assuming no real test gear.)
Set DVM to ACV, hook it across a small (ohmic value) resistor in series with the inductor and use Ohm's law to see how much current flows when the inductor is shorted across the source. The resistors and source resistance add some impedance, but really shouldnt be significant with an iron choke. If the choke saturates or just isnt very inductive this wont be valid. The choke will likely act as a swinging choke as it wont have much airgap stock, these are tricky to measure properly with a meter... Toroidal core autotransformers such as seen with most variacs have no airgap at all and will saturate readily. Sometimes people take shot variacs and cut the core to press them into ballast service. This is quite a crude method and only gives a guess, in actual service there will be DC to contend with. Im sure there are better ways. Inductor Impedance Calculator.
Be sure your foil hat has a good low impedance ground. |
| Autoformer for crossover - HELP! | hasselbaink | Multi-Way | 3 | 12th January 2008 08:56 PM |
| Autoformer options | AJ | Multi-Way | 8 | 7th November 2007 04:07 PM |
| Autoformer CF amp | Fuling | Tubes / Valves | 11 | 11th August 2004 02:14 PM |
| autoformer preamp | jesserparker | Parts | 2 | 14th March 2004 11:49 AM |
| What's an autoformer? | BAM | Solid State | 1 | 1st January 2002 04:40 PM |
| Page generated in 0.08587 seconds (74.84% PHP - 25.16% MySQL) with 10 queries |
