diyAudio Sponsor
Old 6th April 2007, 07:45 PM   #1
leadbelly's Avatar
Default Help identifying a tube.
I just found a couple of NOS tubes in my dad's junk. One is an NOS RCA 6267, made in Holland.
The other has most of the labelling worn off. It is a dual triode, noval, with a shield between the triodes. I can only make out the last 2 figures of the tube designation, P8. There are some manufacturer codes too, a smudged figgure followed by U6, and on the next line, 45B2. Help?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 6th April 2007, 09:02 PM   #2
Hi Leadbelly,
The 6267 appears to be the same as an EF86.
The other tube might be an ECC88 if the P could be a half-erased 8. But there are a number of similar dual triodes, not all familiar to me. If you could work out the pin connections it may help to find what it is similar to. Perhaps others can help here.
Old 7th April 2007, 12:09 AM   #3
leadbelly's Avatar
Thanks Johan. The pinout is typical noval dual triode: pin 4 & 5 to heater, pin 9 is shield. The "P" can't be an "8", the top left is pretty sharp, there is a chance it could be a "B", but it does look more like an intact "P". There is a chance that the last digit is a "6" and not an "8".
Old 7th April 2007, 12:36 AM   #4
Tom Bavis's Avatar
My vote is for ECC85, 6AQ8. Pinout is right, has a shield, Philips code is tU. Tests like 12AT7, but with 6V heater.
Old 7th April 2007, 12:56 AM   #5
tubelab.com's Avatar
I had come up with a similar conclusion. I t has to be a tube with the EIA base code 9AJ. These include the 6BC8, 6BS8, 6ES8, 6AQ8, 6BZ8, 6DJ8, 6DT8, 6JK8,6KN8,12DT8,17EW8, and a few others.
plates on pins 1 and 6
grids on pins 2 and 7
cathodes on pins 3 and 8
There aren't too many dual triodes that end in 6 or 8.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 7th April 2007, 02:56 AM   #6
leadbelly's Avatar
I guess that's right. The 1st line might read as "tU5" and the 2nd line is the Heerlen triangle followed by "5B2". But it doesn't explain the "P" in the actual tube type which is the only thing clearly readable! It makes sense that it's a Philips tube, my uncle worked for them in the 70's and that's how I think they wound up in my dad's stuff
Old 7th April 2007, 03:14 AM   #7
PCC85?
Help with identifying this DIY custom tube DAC vman71 Digital Line Level 1 1st July 2009 09:39 PM
Help identifying tube amp ikoflexer Tubes / Valves 3 3rd October 2008 12:52 AM
Identifying an unknown tube Rispoli Tubes / Valves 11 5th July 2008 07:51 PM
Help with identifying tube showdown Tubes / Valves 1 24th November 2005 09:05 PM
Help identifying tube tester Andypairo Tubes / Valves 2 31st October 2005 12:30 PM
Page generated in 0.09290 seconds (73.10% PHP - 26.90% MySQL) with 10 queries
