Old 6th April 2007, 06:41 PM   #1
Klimon is offline Klimon  Belgium
Default Tube filaments in series?
Dear tube-lover,
Is it detrimental for tubes of same type and make to wire their heaters in series (e.g. to suit two 6.3V tubes with a 12.5 supply)? I know some tubes have a certain affix indicating their suitability for heaters connected in series, what about your average tube?
Cheers --- Simon
Old 6th April 2007, 06:47 PM   #2
Alain Dupont's Avatar
Klimon,
Go for it, without any problems, but make sure you replace the tubes in pairs...
Alain.
Did live about 10 years in Canada
Back to France since the 1st February 2007.
Old 6th April 2007, 06:56 PM   #3
Scott integrateds wired 4 12ax7s in series and powered them with DC. Only the very early Scotts used AC on their heaters. Also the Dyna PAS preamps use a higher voltage DC and series the heaters... It works fine.....
The stuff you don't know always humbles us.........
Old 6th April 2007, 06:58 PM   #4
I agree with Alain. You should be fine using a pair of tubes from the same production run.
Controlled heater warm up time is important in lengthy strings of dissimilar types rated for the same heater current. None of the heaters get overvoltaged.
Eli D.
Old 6th April 2007, 09:19 PM   #5
Supporting this - best way to get dc on heaters with proper filtering (low current, high voltage). One must just watch the maximum heater-cathode voltage rating if several are used in series.
Old 7th April 2007, 03:22 AM   #6
mach1 is offline mach1  Australia
mach1's Avatar
Some of the odd-voltage variants of common tubes have controlled heater warm up characterisitcs (usually around 11 secs) specially made for series wiring.
You can sometimes get 3V filament versions for a song and series heat them from a regular 6.3V tap.
pm
Au rutti wop-bop-a-loom-bop-a-boom-bam-boom - Richard Penniman
Old 7th April 2007, 07:12 AM   #7
Some of us are old enough to remember directly heated TV sets.
All the tube heaters strung together in series across the mains.
No mains transformer and live chassis
Great fun!
Old 7th April 2007, 09:16 AM   #8
That's a clear answer, and luckily the one that opens possibilities!
Thanx,
Simon
AC or DC current for 300B and 2A3 tube filaments ? Kriskom Tubes / Valves 29 22nd July 2012 03:28 PM
Switching power supply for tube filaments possible??? noyan Tubes / Valves 12 17th September 2008 01:32 AM
Series connection of filaments leadbelly Tubes / Valves 24 15th August 2007 12:12 PM
Tube filaments (heaters) power supply matejS Tubes / Valves 5 12th July 2007 05:50 PM
Low vs High aka Series vs Parallel Filaments ak_47_boy Tubes / Valves 10 22nd April 2007 06:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
