diyAudio Sponsor
Old 6th April 2007, 10:39 AM   #1
diyAudio Moderator Emeritus
ray_moth's Avatar
Default How important is the quality of a triode used as a cathode follower
There are triodes that are not considered to be very good for 'normal' use. I wonder how important tube quality is for cathode follower duty?
Old 6th April 2007, 12:40 PM   #2
Ray,
IMO, the important parameter is gm. Since the O/P impedance is approx. 1/gm, high gm is what I look for.
Poor linearity is taken care of by the 100% local NFB. While not particularly satisfactory as a SE voltage amp, the 12AT7 makes an excellent cathode follower. Even variable mu tubes, like the 6ES8, usually regarded as unsuited to HIFI can make acceptable cathode followers.
Eli D.
Old 6th April 2007, 06:34 PM   #3
Dave Cigna's Avatar
hmmm.... If the output impedance is 1/gm, and gm varies over signal swing, then the output impedance varies too. That can't be good!
It seems to me that a good CF requires a tube with parameters that are constant over the entire operating range.
-- Dave
January 20, 2009: Bush's last day
Old 6th April 2007, 07:07 PM   #4
agent.5 is offline agent.5  United States
How about using a pentode instead?
Old 6th April 2007, 07:12 PM   #5
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Sadly, all active devices have gm that varies with current. As Eli says, you want as much gm as you can get. Further, you want the signal swing to be a small proportion of quiescent current (to minimise the variation of gm).
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 6th April 2007, 09:50 PM   #6
Dave Cigna's Avatar
Of course, but that doesn't imply that all devices are equal. Some show much less variation than others.
It's been said that they make a better CF because of their potentially high gm. But I have to admit that I find the problem of keeping the screen at a constant voltage WRT the cathode enough of a complication that I have not tried them.
-- Dave
Old 6th April 2007, 09:58 PM   #7
Maybe use a separate power supply for the screen
separate transformer, rectifier, choke, capacitors, etc.
Old 6th April 2007, 10:10 PM   #8
EC8010's Avatar
There's no more gm than if you strap that same pentode as a triode (usually very slightly less). I assume you're thinking of some of the final valves such as E810F and E55L. As you say, keeping Vsk constant is a pain, and in the few experiments I've made, not really worth the effort beyond novelty value.
Old 6th April 2007, 10:15 PM   #9
I think that is making things unnecessary complicated. As said, we "tolerate" gm variation in normal voltage amplifiers, and a CF is just the same with the input signal connected differently. Because of the inherent NFB is should basically be that much cleaner than the equivalent voltage amplifier, i.e. not the weakest link in the circuit.
I am also worried about the heater-cathode feed-through, though perhaps small. Rf tubes like the ECC81 is not designed for particular good h-k insulation, as in audio standard. I felt more comfortable raising the heaters to above ground potential; more positive than any cathode if possible. I infrequently had a small problem of this nature with r.f. pentode-triodes (e.g. ECF80).
Old 6th April 2007, 10:23 PM   #10
frank754's Avatar
I have four brand-new-in-box JAN-Sylvania 12AT7WC's I'd be willing to sell for $25 incl shipping anywhere in the US (dated 1974), since I have several of these.
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 01:37 AM
How important is quality for power switch? riotubes Parts 2 13th August 2006 01:53 AM
dissimilar triode for White cathode follower? needtubes Tubes / Valves 6 11th March 2005 02:30 AM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 07:47 PM
Common-cathode triode vs source-follower Hexfet. Circlotron Analogue Source 14 22nd March 2003 08:35 AM
Page generated in 0.12082 seconds (77.01% PHP - 22.99% MySQL) with 11 queries
