diyAudio Sponsor
Old 6th April 2007, 02:11 AM   #1
leadbelly's Avatar
Default Why not so common to split dual triodes between channels?
Maybe it is only my perception, but why is it not more common to see dual triodes split up such that each section is part of a separate stereo channel? Of course I have seen examples where it has been done, but I have seen more examples of designs, for example, where the 2nd triode has been used as a CF in the same channel, even if poorly suited for that task. Is it a practical issue where the wiring can get more cluttered, amp cannot be built as a monoblock, etc., or is there a strong technical reason such as resulting in poor channel separation, as an example?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 6th April 2007, 03:25 AM   #2
Tweeker is offline Tweeker  United States
Channel separation may be degraded, the two section can interact electrically. Often twin tubes are used such that this interaction is harmless. Some twin tubes, such as the 6n1p have an internal screen to prevent it.
Be sure your foil hat has a good low impedance ground.
Old 6th April 2007, 07:09 AM   #3
Geek's Avatar
Heh, I've seen a few amps so carefully designed for channel seperation (seperate boards, even seperate supplies), then switch inputs through a $1 wafer rotary.... making a 130dB seperation design into a 30dB one with the crummy switch
Old 6th April 2007, 02:29 PM   #4
Klimon is offline Klimon  Belgium
Strange, my experience has been exactly the opposite; a gargantuan number of diy se schematics use double triodes as driver tube, one half for each channel. In some (or all?) SRPP circuits using dual triodes, it's adviced not to use both tube halves for one channel (otherwise you would exceed ....... I hope someone can fill-in here ) so obligatory to share a tube between both channels.
Simon
Old 6th April 2007, 02:36 PM   #5
Sheldon is offline Sheldon  United States
Or with a phono cartridge - even the best ones.
Sheldon
Old 6th April 2007, 09:08 PM   #6
Geek's Avatar
Sheldon
You bet!
Bottom line - the tubes I believe are the *least* of the channel seperation worries
Old 6th April 2007, 09:31 PM   #7
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Superstition. There's little reason not to share a twin triode across channels.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 6th April 2007, 09:45 PM   #8
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
agree 158%
sometimes even best way.........especially with SRPP or Mu or whatever called thingies
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 7th April 2007, 12:42 AM   #9
unclejed613's Avatar
capacitive cross-coupling...... it isn't so much a problem if tube shields are used, but then nobody would see the orange glow of the filaments from the front of the amp.....
under the socket, you will occasionally see a grounded shield across the tube socket as well... reduces crosstalk and interstage coupling....
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
How to bias DH dual triodes? leadbelly Tubes / Valves 13 24th February 2009 11:12 AM
triple triode common cathode - only want to use 2 triodes audiowize Tubes / Valves 1 10th September 2008 11:16 PM
Looking for dual power triodes. Shoog Tubes / Valves 26 21st December 2006 07:19 AM
Substituting dual triodes Carlp Tubes / Valves 13 10th June 2006 11:29 AM
Page generated in 0.10343 seconds (76.66% PHP - 23.34% MySQL) with 10 queries
