diyAudio Sponsor
Old 5th April 2007, 08:19 AM   #1
Question Pentode/triode switch question
Hi everybody !
I found this schematic of a el84 output stage with a switch used for toggling between triode/pentode mode, wich i like to build.
Could this switch be a potentiometer so that you could switch gradually - and while the amp is working ?
Kind regards,
Stormo
Old 5th April 2007, 08:59 AM   #2
diyAudio Moderator Emeritus
ray_moth's Avatar
No, it won't work with a simple pot because the screen needs a low impedance feed and you won't get that from a pot on its own. In any case, taking a significant current through the wiper of a pot is doomed to failure. However, you might like to look at the Adjustable distributed load discussion, which is about that very subject.
Old 5th April 2007, 01:45 PM   #3
Cool Ok - but
Thanks for the link to the other thread - lots of information there :-)
But - i did belive that there was no current flowing in to the second grid ?
Kind regards,
Stormo
Old 5th April 2007, 01:58 PM   #4
SY's Avatar
Unfortunately, the second grid does not share your belief.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 5th April 2007, 05:32 PM   #5
--> SY, good answer
Old 12th October 2007, 08:11 AM   #6
Default How to do in PP?
Hi friends,
How to add a triode/pentode switch in a PP amp?
After disconnect 470/470 resistors from B+, what
else I need to do? Where I need to connect them?
Project fragment:
http://server6.pictiger.com/img/7257...pp-el-84--.gif
Blindsjc
Old 12th October 2007, 08:05 PM   #7
ray_moth's Avatar
Try connecting them individually to each plate, so that the screen of each EL84 is connected to the plate of the same tube. The optimum plate loading for EL84 in triode PP is 25% higher than for pentode mode, so you might get more distortion than you like.
If you like what you hear and decide to install a switch to change mode, beware that the contacts will be at B+ voltage. Also, turn the amp off before you switch modes.
Pentode to Triode Switch Sherman Tubes / Valves 39 25th February 2012 11:46 AM
Modding a tonebone to switch to pentode triode operation?Can this be done?? Nicko_Lps Tubes / Valves 7 9th November 2008 11:30 PM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 12:36 AM
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Tubes / Valves 19 15th March 2006 09:15 AM
triode=>pentode Lico Tubes / Valves 3 7th April 2004 07:08 PM
Page generated in 0.09559 seconds (74.57% PHP - 25.43% MySQL) with 11 queries
