diyAudio Sponsor
Old 5th April 2007, 06:29 AM   #1
Default Lundahll 1669A Secondary voltage???
I'm studying Claus Byrith's "4-30" variation on the Mullard where he uses a Lundahl LL1669A PT.http://www.lundahl.se/typelist.html
I'm confused about the secondary voltage whether its 340-0-340 or just 340V !!!!
when I calculate the power -@700V- I get 520W while the Lundahl rating is only 225 VA! the cross section is almost nearly 60 x 40mm which weighs ower4.5Kg! The Lundahl weighs just 2.5Kg
Is it possible that the Lundal's secondary is a single 340V ie 170-0-170!!!?? I'm really confused.
Tarek
Old 5th April 2007, 07:13 PM   #2
pmillett's Avatar
I believe it is 340V across the whole winding, or 170-0-170 if you use the tap. The clue is the note "Sec 1 connected as above"...
Pete
help with transformer secondary voltage reading jarthel Parts 6 17th September 2006 11:48 PM
Secondary voltage for heaters pengboon Tubes / Valves 3 1st February 2006 02:09 PM
secondary voltage vs. primary voltage Stocker Parts 5 11th March 2004 07:41 PM
Toroidal secondary voltage for Aleph Jmertz Pass Labs 6 16th January 2002 07:30 PM
Page generated in 0.07069 seconds (70.64% PHP - 29.36% MySQL) with 10 queries
