Need help; I have "dog leg" shaped waveform on my  amp
Old 3rd April 2007, 06:37 AM   #1
andjur78 is offline andjur78  Australia
Default Need help ahve "dog leg" shaped waveform on my amp
Can anyone help with a good procedure for tuning my guitar amp?
The amp runs 4 x EL34 tubes in push pull and each are running 33mA each tube at the moment but on the oscilloscope there is a "dog leg" shaped sine wave thru the zero crossing (8 OHM load).
Should I increase the bias current on each tube in turn? (There are adjustments pots for each tube)
Old 3rd April 2007, 08:23 AM   #2
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
Looks like it. This is likely to be crossover distortion, caused by one tube ceasing to conduct before the other has started conducting fully, a common problem with Class B or very lean Class AB. Try increasing the current in small increments, to find the point where the kink disappears. (If it doesn't disappear, then the problem is something else!)
Need help; I have "dog leg" shaped waveform on my  ampHide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
What makes Nichicon "muse"/"for audio" caps different ? percy Parts 2 3rd October 2009 05:53 PM
Vendor for pot with "D" shaped shaft d3imlay Solid State 3 3rd February 2008 01:11 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Copyright ©1999-2017 diyAudio
