diyAudio Sponsor
Old 20th April 2007, 03:05 AM   #51
Originally posted by ocha
Hello Andersen!
I am interested in this topic very much. My 300B SE amp copied Sunaudio schematic. I manage to assemble preampli by Tango NP126. I hope that I could see and listen to your system because I am also a fan of Altec. Please contact me by lg2y of YM.
Thanks a lot!
Hello ocha
You're welcome. I live in HCMC and do not use YM. You can email via hvdinh@hcm.vnn.vn.
Can you share your pre schematics and what is the progress so far?
Old 20th April 2007, 06:15 AM   #52
According to the below schematics of Tango NP-126, should I ground pin #8 (S).
Thanks.
Old 10th August 2007, 06:25 AM   #53
Default 6SN7 pre-amp
Hello
I've just got a few questions relating to the attached schematics. Can anyone tell me the difference between using 0.22uf/630V capacitors and 0.47uf/630V ones in the position of 1uf/630V, and can I use 100uf/16V in the position of 470uf/25V, which one is better?
Thanks a lot.
Andersen
Old 14th September 2007, 05:32 PM   #54
MartinV56's Avatar
Hi, the cobra 2 line preamp circuit is similar Sun Audio preamp stage used in 300B, 2A3 and VT-25 amps
Old 12th July 2011, 12:31 AM   #55
Originally Posted by Andersen View Post
Thanks for your advice.
My next project is the ultrapath pre-amp and after that is a pre-amp using 45 tubes.
Old 12th July 2011, 12:41 AM   #56
made in sg VN
Old 12th July 2011, 01:48 AM   #57
krivium is offline krivium  France
Hi Andersen,
this circuit is a SRPP design. You can find general information about this kind of circuit here and even more infos in this article from the same author.
To answer your question for the 100uf it should not modify too much the behavior but i'm not sure about V rating, 16V should be ok but 25V is specified on schematic so better to stand with it.
For the 1uf it's a different problem as SRPP is designed with a defined load Z at target and changing this cap with a different load Z than the one specified for this circuit can alter the BW. EG: 0,47uf with 10k load is about 34hz.
Beware your heater must be 'elevated' at some 60v or so (depend on your B+) for the circuit to behave correctly (see anode to heater limit in tube datasheet).
Old 17th July 2011, 06:00 PM   #58
- My Photo Gallery
SE 6SN7 amp.... JandG Tubes / Valves 24 6th March 2011 11:37 AM
6sn7's irishguy170 Swap Meet 0 15th January 2008 07:09 AM
Help me.......What is the 6SN7 ??????? cd149dc Tubes / Valves 10 17th June 2007 04:09 PM
Is it the 6SN7 or me? arnoldc Tubes / Valves 4 12th October 2006 11:31 PM
6SN7 CCS Cassiel Tubes / Valves 25 14th February 2006 10:09 PM
Page generated in 0.12604 seconds (67.94% PHP - 32.06% MySQL) with 11 queries
