diyAudio Sponsor
Old 2nd April 2007, 02:14 AM   #1
leadbelly's Avatar
Default Any pitfalls to choke derived CT?
I bought a 480V control transformer for my SET, but it has no center tap. I will need to run the input section at a lower voltage if I use my Aikido PCB's to drive the output tubes. Are there any drawbacks to using a choke derived center tap (3rd in picture)?
I guess one precaution would be to have caps rated for the full ++, although I'm not sure that losing the CT is any more likely a failure mode than any other. Is there anything else to worry about, say if the current draw on the ++ was higher than the choke was rated for, will it still work fine?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 2nd April 2007, 02:22 AM   #2
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
may i ask why you need a plus and minus rails in the first place?
Old 2nd April 2007, 02:32 AM   #3
leadbelly's Avatar
As I said in my post, I need to run the input section off a lower B+ because the Aikido PCB's put the upper and lower totem pole sections in the same envelope. So the input section will be roughly 300VDC B+ (which technically will exceed the Vhk but is probably OK judging by reports) and the output section will be roughly 600VDC B+.
Old 2nd April 2007, 02:37 AM   #4
Tony's Avatar
ok, dropping resistor should do it..what is your load current for 300 volts? should not be hard to calculate values.
i haven't tried that circuit and i have doubts that it will work...
Old 2nd April 2007, 02:53 AM   #5
leadbelly's Avatar
Well now I would consider that a pitfall
I was leery of burning off that much voltage as heat but it sounds like I may have no choice.
Pitfalls to warmup delay in DC coupled multiple railed amps? leadbelly Tubes / Valves 3 20th March 2009 07:29 AM
Derived Physics Model of a Planer ESL bshaw147 Planars & Exotics 17 2nd November 2008 08:12 PM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 04:43 PM
Any pitfalls to tapping voltage doubler? leadbelly Tubes / Valves 19 23rd July 2005 04:36 AM
AD1854 pitfalls and first listening results capslock Digital Source 12 9th March 2002 06:17 PM
Page generated in 0.08382 seconds (74.13% PHP - 25.87% MySQL) with 10 queries
