diyAudio Sponsor
Old 2nd April 2007, 12:33 AM   #1
Raiser is offline Raiser  Germany
Default Audio Research D76A bias adjustment
Dear All,
I'm having problems to adjust bias in an Audio Research D76 A. In one 6550 I found about 50mA and it is possible to adjust it. In the other tube there are more than 70mA and it is not possible to bring down this value.
This problem happens in both channels.
I've already changed the 1N4005 as well as 1N5368B and both 50uF x 150VDC in the power supply responsibles for this negative voltage. It remains the same problem.
Thank you for any advice in solving this problem.
Pedro
BOZ bias adjustment help rtate Pass Labs 16 11th July 2008 07:04 PM
Audio Research D150 bias setting Tubesin Tubes / Valves 0 28th January 2007 07:09 AM
KT88 Bias Adjustment batinal Tubes / Valves 7 20th May 2006 05:16 AM
Bias adjustment for power amp? Help please cdl Solid State 11 28th August 2003 03:22 PM
Page generated in 0.06670 seconds (65.44% PHP - 34.56% MySQL) with 10 queries
