Old 28th September 2012, 01:46 PM   #31
SY's Avatar
Here is Mr. Jones in my basement lab demonstrating the correct technique for fabricating speaker boxes.
I was demonstrating the technique and utility of Heyser plots for detecting speaker box resonances- that worked fine. Unfortunately, he then felt obligated to demonstrate his method for measuring leakage inductance in output transformers... no photos of that, I was busy cursing.
Note that this is an add-on to an old thread, since the subjects are related. We are most decidedly in Illinois at the moment.
If there's a sucker born every minute, where do the rest of them come from?
Old 28th September 2012, 02:06 PM   #32
expert in tautology
bear's Avatar
Again, strangely ambiguous images...
_-_-
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 28th September 2012, 02:09 PM   #33
SY's Avatar
No, it's unquestionably pink duct tape.
Old 28th September 2012, 02:41 PM   #34
pointy is offline pointy  United Kingdom
pointy's Avatar
Yer but where is the explosion, the fire, and not to mention the smoke......Kaeer BANG ?
Old 28th September 2012, 04:05 PM   #35
expert in tautology
bear's Avatar
Pink? Some mysterious meaning??
Stuart, we want some solid *evidence*!!
_-_-bear
Old 28th September 2012, 04:11 PM   #36
sonidos is online now sonidos  United States
sonidos's Avatar
Better off in Illinois than in Austin! It would have been even more weird over here!
Old 28th September 2012, 04:16 PM   #37
Speakerholic
Cal Weldon's Avatar
I recognize the shiny spot. That is definitely MJ.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 28th September 2012, 07:15 PM   #38
Bigun is offline Bigun  Canada
Bigun's Avatar
I hope nobody allows you two guys to go into the same hi-fi show together, without extensive insurance !
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 29th September 2012, 06:25 PM   #39
jan.didden's Avatar
Originally Posted by SY View Post
We each have the bad habit of only wanting to write about things where we actually have data. Of course, our data from yesterday are comprised most of the aftermath of showers of sparks, followed by smoke, followed by silence.
Yeah, I know the feeling. Gets boring after the umpteenth time.
Only two days ago I took a screwdriver to the output pins of my new 200V regulator. Boring, really.
jan
It is a capital mistake to theorise before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts - Sherlock Holmes Check out Linear Audio Vol 5!
Old 29th September 2012, 06:45 PM   #40
Pano is offline Pano  United States
Pano's Avatar
The opening date of this thread has been noted, at least by some.
So how tattered is your Morgan Jones? Richard Ellis Tubes / Valves 8 5th January 2008 02:30 AM
Morgan Jones BALANCED? vvs_75 Tubes / Valves 3 3rd April 2007 02:26 PM
Morgan Jones and cascodes Ryssen Tubes / Valves 37 11th July 2006 05:28 AM
Morgan Jones H/P Amp problems PLEASE HELP NotInTheMafia Tubes / Valves 13 21st January 2004 12:33 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
