diyAudio Sponsor
Old 1st April 2007, 03:29 AM   #1
leadbelly's Avatar
Default Published/DIY ultra-low THD designs?
I know that THD doesn't carry much weight in this forum, and those designs which feature low THD using large NFB and such are not too popular, however if you would be kind as to point such designs out and save me some tedious searching, that would be appreciated.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 1st April 2007, 03:35 AM   #2
Miles Prower's Avatar
Default Re: Published/DIY ultra-low THD designs?
Try Googling for the Williamson amp. That was a high gNFB, low THD design.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 1st April 2007, 06:38 PM   #3
leadbelly's Avatar
Default Re: Re: Published/DIY ultra-low THD designs?
Thanks.
Any SE designs?
Old 1st April 2007, 07:52 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Default Re: Re: Re: Published/DIY ultra-low THD designs?
Thanks.
Any SE designs?
Higher THD, terrible transciens?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 1st April 2007, 08:16 PM   #5
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Bob Cordell's desing is both - www.cordellaudio.com , http://www.cordellaudio.com/papers/MOSFET_Power_Amp.pdf .
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 1st April 2007, 08:29 PM   #6
Jeb-D. is offline Jeb-D.  United States
Jeb-D.'s Avatar
If you want low THD in a Single Ended amp, screw the feedback loops and go cathode follower. It's a more natural form of feedback, opposed to loops which arn't quite phase correct. Especially in transformer coupled amplifiers.
Just my .02, as I'm sure some will disagree.
Old 1st April 2007, 10:03 PM   #7
Wavebourn's Avatar
I agree.
Old 1st April 2007, 10:30 PM   #8
phn is offline phn  Sweden
phn's Avatar
What do you mean by low THD?
Ken Shindo promises the following for his 300B SET:
Total Harmonic Distortion: 0.1%.
Signal to Noise Ratio: 110dB.
Intermodulation Distortion: 0.09%
But the question makes little sense.
All of the old Leak amps have a THD of around 0.1 pct. Everybody who has heard them say the TL/12 and TL/25A are the best-sounding Leak amps. Anyone can make a poor sounding amp, be it tubes or whatever.
And there's no tube amp without NFB. A triode has internal NFB, which is the reason it operates different from pentodes and all other components.
Edit: Fixed weird characters thanks to ultra slow, instable, bug infested piece of junk IE7.
Old 1st April 2007, 10:48 PM   #9
sorenj07's Avatar
use firefox.
Old 1st April 2007, 10:52 PM   #10
phn's Avatar
Originally posted by sorenj07
use firefox.
And lose the privilege of bitching and moaning? Where's the fun in that?
Ultra High-End DAC designs for DIY? steaxauce Digital Line Level 61 27th February 2009 06:54 PM
Published designs on DIYAudio and Copyright, Patent and etc issues... Ultima Thule Everything Else 59 4th February 2008 06:25 PM
Any published line array designs? mazeroth Multi-Way 10 18th April 2006 09:46 PM
Page generated in 0.11183 seconds (77.93% PHP - 22.07% MySQL) with 10 queries
