EL84 SE auto bias
EL84 SE auto bias
Old 8th April 2007, 02:03 PM   #11
SINGLEENDED is offline SINGLEENDED  Malaysia
Originally posted by kooltubes
Thanks SINGLEENDED.
Amp works fine. I have used different cap values but 100mf sounds better to my ears.
I have also added 22mf betwwen Vout (pin 2) to ground, the soundstage seems to be scaled down.
I am confused about your suggestions to run the El84 at 104ma using a 12R resistor
When u feed more current . First the vocal sound thicker. Than u have better soundstage. Get rid of the 22mf in pin 2 not required it will create different sound, best if we do not use caps at all but cant help it as we need it here & there .I have tried it with value from 65 - 100ma and i think it sound best at 100ma.
etl
EL84 SE auto biasHide this!Advertise here!
Fixed bias vs. auto bias HFGuy Tubes / Valves 30 14th October 2011 09:45 AM
Auto Bias? lpd Tubes / Valves 0 18th February 2007 03:33 AM
EL84 auto split Tobruk Tubes / Valves 1 16th December 2005 07:51 PM
benifits of auto bias hacknet Tubes / Valves 11 26th October 2004 03:04 AM
auto bias on a Quicksilver KT-88 amp Burnedfingers Tubes / Valves 4 15th February 2003 02:40 PM
