diyAudio Sponsor
Old 31st March 2007, 01:29 PM   #1
Location: Thursday Island, Torres Strait (still Queensland), Australia
Question Subwoofer connections
Howdy, I have a small single ended amp, it uses two 6p13p Chinese valves (tubes) as the outputs. I have two home made busch horn speakers and I'd like to add a sub. I don't have a preamp and run the cd player straight into the amp.
How do I know the impedance of the sub hi-level inputs. I guess that they should be ok, as they are designed to be inline with the speakers. I'm just a little concerned that I might be putting the sub in parallel with my speakers and dropping the impedance.
Should I be?
Thanks in advance.
Old 31st March 2007, 02:14 PM   #2
Relax! Just be sure to buy a SW with speaker level I/Ps. You connect the SW in parallel with the main speakers. Do NOT "daisy chain".
Below the "corner" freq., the SW's crossover presents a relatively high impedance load to the power amp. As a result, the power amp's load is completely dominated by the main speakers.
Since nothing is connected to the SW above the "corner" freq., no current flows there.
Edit: fixed typos
Eli D.
Old 31st March 2007, 02:22 PM   #3
That makes sense.
I'll do that.
I've got to ask though...Why do they have the speaker out on the subs then?
Thanks.
Old 31st March 2007, 02:36 PM   #4
To save money on cables and/or tradition. With "midfi" SS gear it probably matters little. The arrangement I suggested keeps the SW's crossover out of the signal path above the "corner" freq.
Eli D.
c3g connections garbage Tubes / Valves 8 16th October 2010 08:51 AM
43% UL connections Hojvaelde Tubes / Valves 18 23rd June 2009 12:00 AM
BNC connections... Stormrider Parts 2 22nd June 2008 07:24 PM
What are XLR connections?? JuNA Pass Labs 30 24th November 2005 06:47 AM
Page generated in 0.08748 seconds (72.38% PHP - 27.62% MySQL) with 10 queries
