diyAudio Sponsor
Old 30th March 2007, 09:46 PM   #1
audio1st's Avatar
Default Aria 6P14 makeover.
Hi, I am new to tube amps and have bought a cheap Chinese amp as somewhere to start. I have been listening to it for a couple of weeks and I'm very pleased with the sound.
What I don't like is the nasty pcb that everything is mounted onto and would like to junk the board and hard-wire it. I have managed to draw most of the cct after a start from a cct that MOAMPS drew some time back.
What I would like to know is, what the (20k I think) trimmer from pin 7 to ground of the input valves is for and how to measure its effect?
Any other (non obscene) comments for any of the other parts in the cct would be most appreciated..cheers..
Old 30th March 2007, 10:02 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
The pot is AC balance, for maximum of 2'nd order distortion cancellation.
Nice drawing!
What software did you use?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 30th March 2007, 10:40 PM   #3
audio1st's Avatar
Nice drawing!
OK, so you would need an oscilloscope to set that?
I used express PCB (free) but had to draw the valves. (could not use eagle at all)..
A picture of the inside, I expect the large capacitors I fitted are showing my non understanding (ignorance) of tube amps...
Old 30th March 2007, 10:51 PM   #4
Wavebourn's Avatar
Are you going to restyle it for training purposes, or it don't satisfy you sonically?
Old 31st March 2007, 12:56 AM   #5
d2134 is offline d2134  Romania
Send a message via Yahoo to d2134
Hi, audio1st
I have a question: is it a poor quality PCB or you like more point-to-point wire?
I'm curiouse to see a picture of the original PCB, can you post one?
Old 31st March 2007, 06:18 AM   #6
Svein_B is offline Svein_B  Norway
This Aria Mini is almost identical to the Yarland FV-34C III described in a previous thread (incl. diagram) here
I agree that the small PCB make modifications more than a little difficult.
SveinB.
Old 12th April 2007, 03:23 PM   #7
audio1st's Avatar
Makeover finished, hardest part was removing the last bit of hum.
The 330ohm resistor where the feedback connects to, had to be earthed via the pot ground. My thanks to SY for his earth suggestion on another thread that allows me to connect the case to a safety earth without causing ground loop hum...PS sounds great..
Old 12th April 2007, 03:24 PM   #8
audio1st's Avatar
The finished diagram..
How Set up Aria Mini 6P14? callagan Tubes / Valves 2 29th July 2009 12:12 AM
ESS AMT 1A Monitor Xover makeover diamondsouled Planars & Exotics 0 7th August 2008 03:41 AM
CD Makeover!!! sandstorm33 Digital Source 4 14th February 2007 12:21 AM
Silvertone 1472 Makeover Gunny Tubes / Valves 2 25th February 2006 07:39 PM
ARIA 7 Focal Kit jleaman Multi-Way 0 27th May 2002 01:36 AM
Page generated in 0.10669 seconds (77.81% PHP - 22.19% MySQL) with 11 queries
