diyAudio Sponsor
Old 30th March 2007, 04:34 AM   #1
Default Quiet Tube
Hi guys,
I am looking for non-microphonic, quietest 9-pin twin triode tube. As I am frustrated from differentiating tube (internal) noise and other externally generated tube oise.
Please kindly recommend
Audio_Idiot
Old 30th March 2007, 04:54 AM   #2
rcavictim's Avatar
Try a 2N6CG7.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 30th March 2007, 07:42 AM   #3
Geek's Avatar
I have a box full for JAN GE 5751's that fit that description
Old 30th March 2007, 07:53 AM   #4
SY's Avatar
Quietest in what circuit? Context is everything.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 30th March 2007, 08:08 AM   #5
oshifis is offline oshifis  Hungary
I used Tungsram PCC88 for moving coil amplifier, and I could reach 60 dB S/N ratio (A weighted). E88CC is also very good, although a bit less quiet.
Old 30th March 2007, 08:18 AM   #6
Tweeker is offline Tweeker  United States
I have some 6L6s with white powdery getters. They are very quiet, but octal.
Be sure your foil hat has a good low impedance ground.
Old 30th March 2007, 08:20 AM   #7
As ground cathode.
Audio_Idiot
Old 30th March 2007, 08:28 AM   #8
SY's Avatar
OK, that's one bit. Signal level? Source impedance? Load? EQ? Noise weighting? You've barely scratched the surface.
Old 30th March 2007, 08:45 AM   #9
Input signal the usual 1Vrms, Don't know much about noise weight of the input signal... will just have to rely on the meanufacturer's "usual standard".
I recon the PS noise ripple for the tube is about 0.04V but then I've yet to regulate the PS, so lots of room for improvements, I actually tried using noise injection at the cathode for noise cancellation, but since I do not have access to a scope so no maeasurements... This is the rational of asking for a quiet tube so that I could at least identify and sort out my "others" problems...
As for the stage gain, I really is not particular about it, as I'll probly cascade into anothe gain stage. I'll be happy with 10~30x.
I tried 6C45p, then to 6922 then, 6N1P, then 5965 then5842, then.... I'd lost trrack... but the sound is infested with a little hum which is only audioble 2" away, Also, a tat of white noise and which will getting to my nerves when listening in the depth of the night...
I hope these info got my skin scratched:-)
Cheers
Audio_Idiot
Old 30th March 2007, 03:36 PM   #10
Other things to be checked are heater dress and EMI (such as from transformers or chokes.) If the hum fundamental is 50/60hz and not 100/120 this is an indicator of heater or xfmr related noise.
You may also have dirty power and/or RFI.
How quiet is dead quiet? pchw Tubes / Valves 36 22nd November 2007 04:36 AM
Gainclone too quiet? drfrink24 Chip Amps 13 14th March 2005 08:57 PM
Quiet here, isn't it? pinkmouse The Lounge 24 8th February 2005 08:29 PM
How quiet will it be? MMicke Chip Amps 8 12th July 2003 08:26 PM
Too quiet! grataku Everything Else 14 14th February 2003 04:39 PM
Page generated in 0.08843 seconds (84.23% PHP - 15.77% MySQL) with 10 queries
