diyAudio Sponsor
Old 30th March 2007, 12:56 AM   #1
mus is offline mus  Canada
Default LM385 Adjustable voltage ref. diode as LED bias?
Hi Guys,
I'm wondering is the LM385 would do a better job then LED as for cathode bias? The LM385 can be adjusted from 1.24V to 5.3V and its dynamic impedance is 1 ohm. The data sheet is http://www.national.com/ds/LM/LM185-ADJ.pdf
Old 30th March 2007, 04:25 AM   #2
Brian Beck's Avatar
Here is what an LM385 really looks like to your circuit. Compare to the "schematic" of an LED.
Brian
Old 30th March 2007, 04:27 AM   #3
Brian Beck's Avatar
Which leads to this kind of behavior. Compare to the dynamic Z of an LED.
Brian
bias supply question / sanity check - adjustable resistor? ilted Planars & Exotics 0 5th May 2009 02:12 PM
Schottky diode bias pointy Tubes / Valves 10 5th April 2009 03:13 AM
adjustable voltage regs compatability KevinLee Parts 1 16th December 2008 07:18 PM
Adjustable Fixed Grid Bias dsavitsk Tubes / Valves 5 4th December 2007 03:58 PM
how do i add adjustable bias on amp? AudioGeek Tubes / Valves 2 26th September 2005 02:27 AM
Page generated in 0.07244 seconds (69.60% PHP - 30.40% MySQL) with 11 queries
