diyAudio Sponsor
Old 29th March 2007, 09:32 PM   #1
aletheian's Avatar
Default Any spice models around for AA5-esque battery tubes?
You know... little directly heated guys: 1T4/DF91, 1U5/DAF92, 3V4, 3S5, etc. I had a few in pentode and triode mode traced out in Curve Captor, but my hard drive crashed and I lost them... and i have not reinstalled Curve Captor or any of the Tcl support... or even my full operating system.
if anyone has some, I'd greatly appreiciate it.
Heghlu'meH QaQ jajvam!
Old 30th March 2007, 12:05 AM   #2
I can't help with Spice.
The tube complement I can help with. 1R5 pentagrid converter as combined 1st detector/local oscillator. 1T4 remote cutoff pentode as IF amp. 1S5 diode/pentode as 2nd detector/AGC rectifier and AF voltage gain. 3S4 as audio O/P.
67.5 V. B+ is enough. You'd want 90 V. B+ for a 3V4 "final".
If you can scrounge up a 3 section tuning cap., a 1U4 TRF gain block will IMPROVE image rejection.
Eli D.
Old 30th March 2007, 12:35 AM   #3
aletheian's Avatar
Thanx. I am trying to spice a few things to improve my understanding and to experiment... for example, I still can't get simple AVC like you see in these old radios to work right unless i dupe a previous circuit. i also have piles of those little directly heated pentodes around and want to experiment with them a bit, but would rather spice the whole thing first.
spice models for led fscarpa58 Parts 18 10th August 2009 10:16 PM
Spice models Grahamm Tubes / Valves 7 19th December 2006 01:36 PM
new spice models available Joel Tubes / Valves 31 7th April 2006 05:10 PM
spice models Zoran Solid State 11 17th September 2005 02:03 PM
Page generated in 0.07396 seconds (67.65% PHP - 32.35% MySQL) with 10 queries
