is this the correct way of adding a volume control?
Old 29th March 2007, 06:24 AM   #1
jarthel is offline jarthel  Australia
Default is this the correct way of adding a volume control?
Here is a an aikido circuit used as a headphone amp: http://www.tubecad.com/2006/04/27/ai..._amplifier.png
Problem with the circuit is that volume control is missing. A requirement for a headphone amp.
I'm just wondering if this is the right way of connecting a pot to the circuit above: http://img261.imageshack.us/my.php?i...controlsn8.png
thank you for the help
Old 29th March 2007, 08:50 AM   #2
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
Looks OK to me. 100k (audio taper) should be a fine choice.
I also like the way you're planning to retain the 1Meg resistor R1. This will help prevent nasty noises in case the volume control wiper is not a perfect contact to the track. The only thing you might need to add is a coupling cap at the input, but only if the signal source has any DC bias on it.
Old 30th March 2007, 01:12 AM   #3
how do I know if the input has DC bias?
thanks again
Old 30th March 2007, 01:44 AM   #4
Audio_idiot is offline Audio_idiot  Malaysia
Original post by jarthel
Since ther is no reply to this question, I will try to contribue my 2 cents worth.
What I will do is to measure the signal's DC voltage across the signal to ground with a multimeter. It's fine if it fall around +/-40mV. (smaller the better.)
But you don't have to worry too much, this DC Voltage is normally very small, and at worst shift the bias of the front stage by a volt or 2, I recon the 2 triodes in your Aikido's front stage will try to balance the effect off by themselfs. and since there is an output coupling cap, this DC signal will not get through to your headphone and ruin it.
I'm still a student in this, so, I hope its the correct.
Cheers
Audio_Idiot
Old 30th March 2007, 10:32 AM   #5
ray_moth's Avatar
As you say, a little DC may not be especially bad as far as the IP tubes are concerned. However, if there is any DC, even if it's not enough to upset the input tubes, will cause the volume control to have a noisy travel. Better to use an input cap only if necessary.
is this the correct way of adding a volume control?Hide this!Advertise here!
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 08:20 PM
Adding volume control to Lite DAC-AH jaykick Digital Source 9 12th September 2007 08:32 AM
Adding a Volume Control(PLEASE HELP) jodogzzz Everything Else 0 8th October 2006 12:19 PM
Copyright ©1999-2017 diyAudio
