diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Basic DIY Valve Phono Stage (http://www.diyaudio.com/forums/tubes-valves/99037-basic-diy-valve-phono-stage.html)
matthew2456 28th March 2007 09:24 PM
Can anyone recommend a relatively low cost a good sounding phono stage.......?
phn 28th March 2007 09:29 PM
http://www.geocities.com/rjm003.geo/.../diy_pho3.html
Eli Duttman 29th March 2007 12:20 AM
2 Attachment(s)
There's always the "classic" RCA design, which is seminal to all passive designs. You'll need to add a buffering voltage follower if a stand alone project is what you have in mind.
No matter which design you settle on, a DC heater supply is a must.
Edit: fixed typo
dsavitsk 29th March 2007 01:16 AM
Is a 12ax7 close enough to use in this circuit, or is the 7025 essential?
Eli Duttman 29th March 2007 01:31 AM
With DC heating, 12AX7s are FINE. The 7025 is a 12AX7 with a spiral wound hum bucking heater. The current production Sovtek 12AX7LPS is a 7025 equivalent.
While you MIGHT be OK using AC heating on the 'LPS, why take the chance, when setting up a 7812 regulated heater supply is really easy.
hagtech 29th March 2007 05:11 AM
http://www.hagtech.com/images/cornetschem.gif
jh
Copyright 1999-2017 diyAudio
