diyAudio Sponsor
Old 28th March 2007, 01:30 AM   #1
leadbelly's Avatar
Default Best SET driver stage with lots of B+?
I am still researching how I would like to build my SET 6L6GC amp. I have a 480V control transformer, and a hybrid bridge with 6AX4's to get 500+ B+. I have been acquiring various candidates for input/driver tubes such as EF184, 1579, 6H8C, 6N6P, 6H30 for this and other projects.
My question is, when you do have plenty of B+ available for your input/driver stage, how best to use this to advantage? One technique I see is a hybrid pentode/SS CCS for plate loading, which needs quite a bit of voltage to work, and I like the idea of a EF184/SS CCS plate loading a triode strapped EF184 as driver. What other techniques can I research, or if too broad a question, what's your favourite?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 28th March 2007, 02:39 AM   #2
agent.5 is offline agent.5  United States
I will try the following 2 options:
[1] choke loaded DHT that can take higher voltage. Suggestions: 75TL, 100TL, 100TH, 3C24, 801A, GM70
[2] Aikido type driver stage, with say a 45 loading a 45.
Old 28th March 2007, 08:00 AM   #3
Tweeker is offline Tweeker  United States
Will 6l6GC as triode really like that sort of B+? You might consider a choke input supply, unless your trying to direct couple or something.
One not so fancy answer to what do do with lots of B+ is to just use a big plate load and LED bias for the pre tube. Possibly with "e-linear" feedback OPT allowing- plate load resistor connected to OPT UL tap.
A cross coupled Aikido using 2 identical tubes (such as the 6H8Cs [6N8C], 6N6Ps or 6N1Ps) would also work, the top triodes in one envelope, bottoms in the other.
None of these tubes really make sense driving 6L6GCs.
45s are rather expensive, and Aikido gain is only about half mu. Gain of the stage would be less than 2. Also 2 filament supplies, one floating, would be a pain.
Be sure your foil hat has a good low impedance ground.
Adcoms with lots of DC offset. Lots! ben62670 Solid State 71 16th February 2010 03:01 AM
24 or 24a as driver in 2 stage..? JandG Tubes / Valves 3 30th December 2008 12:43 AM
Need a serious PP driver stage Fuling Tubes / Valves 19 30th October 2007 08:08 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Mu stage driver lndm Tubes / Valves 19 22nd September 2006 02:57 PM
Page generated in 0.08711 seconds (72.15% PHP - 27.85% MySQL) with 10 queries
