| diyAudio Sponsor | ||
Hi ,
please criticize this idea . Sure its nothing new here , but maybe something can be done better . I will try AC and DC filament for both tubes . |
#2 |
Surely this is a very interesting project. I believe it is better to use DC supply for the VT-25's filament to avoid excessive hum pickup at the first stage.
Also, the gain of this amp is very low and you need to drive it with a high gain line amp. Johnny |
#3 |
yes I know about gain , I will need about 5-6 V RMS to drive that amp properly , but I got right preamp for that . Those gonna be mono amps . My main concern is about that beautiful Tango interstage transformer - it is 5K , but VT-25 sugested load is 10K . I don't wanna push vt25 to much .Anyway maybe not a big deal because thats not an output transformer stage .
#4 |
you could solve the gain problem and go a step further along the Sakuma path putting an input transformer in the circuit. Unfortunately ISO-Tango doesn't make input xfmrs anymore, but you could still use a tamura one. Maybe a TN-351 just to have a 2x gain and not so low an input impedance. If you have a preamp with an output xfmr with 600 ohm output impedance, you could use an input xfmr with 600 ohm primary and have much more gain. Just my two cents, Enrico |
#5 | |
Andreas |
#6 |
gain isn't a problem here . I think 2 trafos more than enuogh for me
#7 | |
John |
#8 | |
tarmac ripper
#9 | |
John |
#10 |
tarmac ripper
The freq response will fall at low freqs because the gain of the tube falls because the load falls. The load line IS affected by primary inductance.
Ciao Gianluca |
| help needed for 1st DIY tube amp - Sakuma 845 SE | glower | Tubes / Valves | 18 | 24th September 2011 03:17 PM |
| Sakuma-San Pilgramage? | wrenchone | Tubes / Valves | 5 | 7th January 2009 07:26 PM |
| Tango PRO pcb | vangelis | Parts | 2 | 3rd November 2008 07:26 AM |
| Need Tango U-808 | revintage | Swap Meet | 0 | 24th June 2007 09:29 PM |
| Tango 600 | Onvinyl | Analogue Source | 0 | 4th March 2005 10:49 AM |
| Page generated in 0.11462 seconds (77.14% PHP - 22.86% MySQL) with 11 queries |
