diyAudio Sponsor
Old 26th March 2007, 04:23 PM   #1
Default I'm looking for 417a/5842 Preamp Schematic without any Transformer, any suggestion ?
does anyone ever built using this tube for Preamp without using any transformer and still get the best sound Quality ?
I've googling the schematic but they are using transformer, all I need is a Simple Schematic with less component use.
any Schematic recommendation ?
cal
be tube
Old 26th March 2007, 05:42 PM   #2
phn is offline phn  Sweden
phn's Avatar
Replace the trafo with a 3 to 5 k resistor. But you will get very high gain.
Better use 12B4, 407A or 5687.
Old 26th March 2007, 06:06 PM   #3
phn's Avatar
Sorry for the hasty, incomplete answer.
You need to change B+ to 250V and the transformer replaced with a 4.7k resistor. But, again, you will get a lot of gain. 1 volt in will be 30 volts out. Most power amps have a sensitivity of 500mV or less.
Old 27th March 2007, 02:05 AM   #4
phn,
thanks you for the advice.
ok, I have limited space and I need little/less component or I should say very very simple design.
how big the interstage treansformer are we talking here ? how much it cost and where to buy beside ebay ?
can you show me the good Schematic preamp using this tube ?
or can you recommend any other tube better than this but no OT design ?
cal
be tube
Old 27th March 2007, 08:42 AM   #5
barossi is offline barossi  Germany
Hi Cal,
i have good experiences with Lundahl LL1660/18mA together with the 5842 tube. Search for "EURIDICE" and you will find a schematic.
Kind Regards
Barossi
Old 27th March 2007, 01:00 PM   #6
Barossi,
I can't find the schematic you said.
found the 4 channel, etc.
I'm looking for the preamp 417a/5842 Schematic that doesn't use any Transformer.
thanks
cal
be tube
Old 31st March 2007, 07:11 PM   #7
dshortt9's Avatar
I finally found the one that I forgot where it was. Should be really good.
http://www.diyparadise.com/mar06/gg.html
Old 31st March 2007, 08:46 PM   #8
bear's Avatar
Thorsten Loesch, Steve Bender and Allen Wright have all published on the web very nice preamps using the 417A as the front end tube.
For best results use it as cascode with a JFET for MC carts.
_-_-bear
_-_-bear
http://www.bearlabs.com ...live within ~60mi of Albany NY? contact me! --
WTT: One Telefunken EF804 tube for one WE 5842/417A GordonW Swap Meet 0 15th April 2008 03:00 PM
Testing 5842 / 417a satelitis Tubes / Valves 1 23rd September 2007 05:36 PM
Confused, datasheet of 417A/5842 CLS Tubes / Valves 9 22nd August 2006 03:14 AM
Which valve, 5842 (417A) or 6H30 eeka chu Tubes / Valves 1 30th October 2005 01:08 PM
Substitute for 5842/417A Peter Menting Tubes / Valves 14 10th December 2003 10:55 AM
Page generated in 0.08650 seconds (74.78% PHP - 25.22% MySQL) with 10 queries
