| diyAudio Sponsor | ||
What PT's & OT's ( brands & model numbers) are suitable for the following schematics? Are there any models -especially OT's- that can be used for most? Dynaco Low Power (6V6/6BQ5/EL84) Amphttp://www.triodeel.com/dyna6bq5.gif Dynakit Stereo Preamp model PAS-2 -PT only-http://www.curcioaudio.com/pas_mnl.pdf Claus Byrith variation (4-30) on the Mullard 5-20 -other that the Lundahlhttp://www.lundahl.se/pdfs/claus_byr...fier_30wpp.pdf Eico HF-20http://www.triodeel.com/eicohf20.gif Grommes 215-BAhttp://www.triodeel.com/gromm215.gif |
#2 |
Didn't look at the PDF's, but for the others... 6AQ5/BQ5/6V6, you can use: http://www.edcorusa.com/products/tra...25-8-7_6k.html 807 == 6L6 for plate Z. You can use: http://www.edcorusa.com/products/tra...60-8-6_6k.html Cheers! |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| WTB gainclone-suitable (18-0-18 to 25-0-25) transformers, MUR860's,soldering station. | Spasticteapot | Swap Meet | 4 | 20th March 2006 05:22 PM |
| Looking for Amp project suitable for a 35V and 15V Transformers? | bezobraznia | Solid State | 18 | 10th February 2005 11:54 PM |
| Are these transformers suitable? | NewVintageNut | Chip Amps | 12 | 24th September 2004 06:54 PM |
| Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? | Layberinthius | Tubes / Valves | 0 | 11th March 2004 08:49 PM |
| Page generated in 0.06578 seconds (67.27% PHP - 32.73% MySQL) with 10 queries |
