How to measure frequency response with a PC?
Old 25th March 2007, 10:21 PM   #1
zafira1981 is offline zafira1981  Argentina
Default How to measure frequency responce with pc
Hi people,
I'm trying to measure the F.R. of my tube amp (http://www.diyaudio.com/forums/showt...threadid=97002) and I cant make TrueRTA work.
I tried with NVIDIA SoundStorm sound card an Sound Blaster Audigy 2 ZS. I cant calibrate the sound card to have a plain frequency response to start measurements.
I don't know what is my mistake.
Sound Controls (both cards tested):
recording: line input selected, at MAXIUM
playback: wave and master at maxium, line input muted (To avoid oscillations)
Loop cable conected between line in and line out.
I also checked and no "audio effect" is ON.
Any clue? Any other program to use?
Old 25th March 2007, 10:46 PM   #2
Gold_xyz is offline Gold_xyz  Italy
Gold_xyz's Avatar
Hi
Try an oscilloscope/spectrum analyzer from this site
http://digilander.libero.it/hsoft/
Link download : http://digilander.libero.it/hsoft/VA.zip
(with continous spectrum )
My English originates from here
Old 26th March 2007, 12:39 AM   #3
TugaTweaker is offline TugaTweaker  Portugal
This can be useful too .
http://www.usb-instruments.com/oscillo_stingray.html
Old 26th March 2007, 02:35 AM   #4
Originally posted by Gold_xyz
Hi
Thanks for your reply!!!!
I've downloaded the program. I'm trying to calibrate it. Wave generator is configured as Sweep. After a few loops, the graph shows the frequency response of the sound card:
Is there any way to "flat" it to correct the response of the sound card?
thanks
Jorge.
Old 26th March 2007, 08:42 AM   #5
Sylvania is offline Sylvania
Hi
try this -> http://audio.rightmark.org/products/rmaa.shtml with this program you can subtract the soundcard data from your amp's data.
Best regards Kim Olesen
Old 26th March 2007, 01:12 PM   #6
Originally posted by KimBOlesen
Hi
Wowww that program seems to be really nice!! thanks!! I will try it. thanks!!!!
Jorge.
Old 26th March 2007, 01:33 PM   #7
Svein_B is offline Svein_B  Norway
I often use ARTA, the speaker measurement program also for amplifier measurements.
- The Spectrum analyser is nice for measuring harmonic distortion, and it has built in tone generators.
- Compensation files can be loaded.
- FR measurement is OK, but most PC's fall short here with a limit of 20KHz. The same can be said for usefulness of any soundcard based oscilloscope.
Svein B.
Old 26th March 2007, 02:02 PM   #8
Conrad Hoffman is offline Conrad Hoffman  United States
Zafira, I like VA quite a lot. If your sound card can sample higher than 44.1khz, you can test higher than 20khz. My inexpensive E-mu 0202 USB box supposedly can go to 192khz, though I haven't pushed it that far. Tests at 40khz (96khz sample) and more seem fine. I notice that your level is -60 db in the graph you attached. That's way down there- check your levels and 0dB setting. You might also find it interesting to use the pink noise source and set the analyzer for 1/3 octave or finer measurements. Handy when you move beyond the amp to the speakers.
Old 27th March 2007, 12:33 AM   #9
nhuwar is offline nhuwar  United States
nhuwar's Avatar
As far as hardware goes iIve been eyeballing this. ! channel o scope 400hz to 16 mhz spectrum analyzer.
http://www.velleman.be/ot/en/product/view/?id=348712
Nick
Old 27th March 2007, 04:16 AM   #10
kevinkr's Avatar
I believe if you are using line in and out and doing a loop back test the line input needs to be unmuted - that is where the signal you are trying to measure is connected to.
There should be no oscillations with loopback connection and both input and outputs enabled.
Note that depending on level settings and sound card you may clip either the input or output, this should be fairly obvious if you get high thd numbers.. I generally run at no more than 90% of digital FS to get good results.
I use Arta and Audio Tester.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
How to measure frequency response with a PC?Hide this!Advertise here!
Easiest software to measure the Frequency Response -_nando-_ Multi-Way 72 15th July 2007 06:21 PM
How to measure frequency response with PC? Emiel Multi-Way 8 3rd November 2005 06:09 PM
What software to MEASURE response Madmike2 Multi-Way 3 6th July 2005 09:19 AM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 11:39 AM
