| diyAudio Sponsor | ||
Dear All,
Anyone used Vacuum State dpa300B power amp before? Any comment on it? I'm now consider to buy this power amp. Thanks a lot! Best Regards |
#2 | |
Account Disabled
Are you considering building a kit, or are you going to be buying the DPA-300B amps ready built? |
#3 |
In theory the DPA300B should be one of the finest amps availble. I based my current amp design on the differential aspects of this amp. I also built a version of the FTP5 preamp and the sonic characture of this preamp is very pure. I would guess that the DPA300B is probably the nearest to wire with gain that its possible to get in the field of Valves.
Shoog |
#4 | |
Account Disabled
But what about all those juicy harmonics? To borrow Allen Wright's metaphor, maybe I do want chocolate sauce on everything. I mean, what is the point of building a valve amp where the valves are so tightly bootstrapped? It's sort of like not letting valves be themselves, in a manner of speaking. But it's worth doing, because for me the alternative is trying to build Lynn Olson's Karna amp, which would mean sourcing every component myself, and having to set up a small workshop to make a chassis, and I really don't want to do that. |
#5 |
Funny you should mention the Karna amp. My current amp uses the differential aspects of the dpa300B, and the interstage phase splitting of the Karna.
I know what you mean about wanting a bit of distortion - but to be honest my experience is that valves are intrinsically the least distorted amplifiers of the lot and its only poor design that allows distortion in. PP is definately the way to go. Its not so much that the bass is thin in SE designs, more that its woolley and indestinct. I think that a design like the Karna or dpa300B will produce the type of midrange detail of a SE, but without the high frequency roll off which makes it sound to smooth for my taste. The woolley bass of SE can also be attributed to a lack of ultrasonic detail which has the effect of adding the snap into bass passages. Shoog |
#6 |
Account Disabled
Snap. That's the word I was looking for. It's reassuring to hear that the DPA-300B could deliver the midrange I'm after. I sure hope so, because kit or no kit, these things are by no means that easy to put together. Well, not the RTP3D preamp, anyway. Because of the latest design change, the component count has crept up, and things are getting rather crowded.
I've seen a discussion on a forum somewhere contrasting Allen's and Lynn's design philosophy; interstage transformer coupling contrasted with RC. In some ways I like Lynn's design more. There's an irony in taking a 1930s Western Electric design and combining it with technology unavailable at the time -- SS-based constant current sources. It's making some kind of statement about being true to proven designs but across a long timespan. |
#7 |
From my reading - anyone who has heard interstage transformer phase splitting would never ever go back to RC coupling. Unfortunately these transformers as very expensive and need serious drivers to get them to give of their true potential. Beyond the the scope of most single build DIYers.
Most bottleheads seem to avoid CCS because they think they want that distorted sound. I use CCS where ever I can put them. Even a triode based CCS brings benefits, and its the lowest performing one of the lot (you would already know that from your preamp build). Shoog |
#8 | |
Hi Shoog
Erik |
#9 | |
Account Disabled
#10 | |
frugal-phile(tm)
When we are considering building PP amps this design always serves as one of our reference designs ... one of these days i hope to build one. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Vacuum State SuperREGS | tubesguy | Swap Meet | 5 | 1st March 2009 03:05 PM |
| Vacuum State RTP5. | InSides | Tubes / Valves | 4 | 15th March 2008 04:40 PM |
| My version of the Vacuum State FVP5 | Shoog | Tubes / Valves | 67 | 18th January 2008 04:26 AM |
| Vacuum State Electronics FVP5A | runeight | Tubes / Valves | 28 | 5th December 2003 10:46 AM |
| Page generated in 0.12855 seconds (80.40% PHP - 19.60% MySQL) with 11 queries |
