SS PSU without choke - Page 3 - diyAudio
Old 14th January 2003, 09:40 PM   #21
diyAudio Senior Member
fdegrove's Avatar
Default ANODE RESISTOR
(Elfa) only had 47k at 10W. Is it bad to have 10W instead of 1W?
It will be inductive and as such be non-linear.
47K is such a common value that you may find it around the corner.
Better take a 1W metalfilm.
Frank
Old 15th January 2003, 09:12 AM   #22
I have put two choked psu's on my webserver so you can have a look at them. Please tell me what you think, and also tell me how to improve it.
http://213.67.45.70/no_ripple.psu
http://213.67.45.70/no_ripple2.psu
I haven't taken my need for 400V into consideration, I just wanted to test how much a choke could filter my psu. And the results are breathtaking if you ask me.
Old 15th January 2003, 11:39 AM   #23
jan.didden's Avatar
Default Re: ANODE RESISTOR
Frank,
Not wanting to split hairs, but an inductive resistor is not necessarily non-linear. Its impedance does change with frequency, but ususally this is a linear change. I mean, all resistors have a tempco, which means the resistance changes with temperature, in a linear fashion.
Jan Didden
Old 15th January 2003, 04:58 PM   #24
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Split the hairs even further..
Most film resistors are inductive too. That's why one of the few sanctuarys left for the carbon composition resitor is RF circuitry.
Old 15th January 2003, 05:08 PM   #25
fdegrove's Avatar
Default Re:Splitting hair.
Now I know where that noise comes from.
Seriously,carbon comp is not inductive?
I didn't know that.
Frank
Old 15th January 2003, 05:09 PM   #26
Bas Horneman's Avatar
Mikael,
Bottom line...use the 10watt resistor...until you run into some nice riken ohm, kiwame, mills or dale ns, and just solder the little buggers in and tell us if you heard a difference!
Bas
Old 15th January 2003, 05:16 PM   #27
dhaen's Avatar
Default Carbon composition resistors
Frank,
If you're in a definite and black & white answers mood, of course.
They are as inductive as the wire connecting them (length for length).
This leads to a resonant frequency of about 4GHz - 10GHz.
Now, my hearing doesn't quite reach that far but maybe yours does
Am I worried
Just don't put one in your microwave oven!
Old 15th January 2003, 05:21 PM   #28
dhaen's Avatar
Default 10watt WW in anode
In all seriousness, IMO this is not desirable in the long term.
In the short term, it'll probably be fine.
If you hear any radio stations in the background, you'll know it's time to change it.
Old 15th January 2003, 05:28 PM   #29
Send a message via AIM to BeanZ
I know that this thread has moved passed this now but for the future: A choke is a term designated to an inductor operating with a DC bias current. The "inductors" used as output filters in switching power supplies are actually chokes because they operate with a DC bias and filter ripple current.
BeanZ
BeanZ
Old 15th January 2003, 05:34 PM   #30
dhaen's Avatar
BeanZ,
That sounds the most credible explanation so far.
Do you know the origins?
PWM for car choke? Dan2 The Lounge 35 15th June 2008 12:17 PM
Choke rating for choke input duty cbutterworth Tubes / Valves 14 9th November 2007 05:43 PM
Swinging choke vs std. choke in PS Curly Woods Tubes / Valves 2 5th March 2007 09:30 PM
Swinging Choke or Smoothing Choke danFrank Tubes / Valves 4 11th February 2007 12:05 PM
L as a choke. bogdan_borko Solid State 9 9th September 2006 10:48 PM
Copyright 1999-2017 diyAudio
