diyAudio Sponsor
Old 23rd March 2007, 01:30 AM   #1
Banned
Default Regulated heater reference
I've this regulator for the heaters of four EL34 tubes. The reason of two regulators on top of one another is the lower portion of voltage lost in rectifiers than if I had only 6 V for output.
My question is, since the cathodes sit around -350 V, how do I reference the heaters to that so that the heater to cathode potential rating is not exceeded, without frying the regulator's low voltage components? The thing is, a relay delays the HV so when the heaters come on initially, there's no voltage applied to the tube's cathode or plate, and the HV supply is not even on (the relay is before the rectifiers since relays have much lower DC ratings).
Old 23rd March 2007, 02:21 AM   #2
SY's Avatar
If you draw an actual schematic, it will be easier to answer your question. I got a headache looking at that! You needn't throw in every wire resistance.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 23rd March 2007, 03:18 AM   #3
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I would connect filaments in series instead of using 2 regulators. Also, I don't understand why do you need a regulated supply for filaments of power tubes.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 23rd March 2007, 03:24 AM   #4
FastEddy's Avatar
" ... I don't understand why do you need a regulated supply for filaments of power tubes. ..."
'cause most heaters have an AC source, which injects an added noise component into the tube where the action is ... sometimes this AC noise can leak into the audio amplification resulting in, well, extra noise on the audio sgnal ... Sy?
Old 23rd March 2007, 04:05 AM   #5
Banned
I don't think the details matter. Here's an abstracted version.
http://img482.imageshack.us/img482/8840/hregqb9.png
Old 23rd March 2007, 04:05 AM   #6
Banned
The matching of filaments is not that great, so in series doesn't work well. Now, the mismatch would seem to be just as bad in parallel except for the fact that filaments are not simple resistors but their resistance varies with temperature. For EL34 tubes I find in parallel works better. However, I can't have all four in parallel since then I get twice the rectifier loss and I don't have enough voltage overhead with this transformer.
In any case, this still doesn't address my original question.
Old 23rd March 2007, 04:05 AM   #7
Banned
These tubes are driving electrostatic headphones, and I want the lowest possible noise floor. I've even shielded the power supply separately from the amp.
Old 23rd March 2007, 10:11 AM   #8
SY's Avatar
The details absolutely do matter. There are two considerations- noise injection and heater-to-cathode ratings. Without an actual schematic, it's difficult-to-impossible to lay out the correct way of setting up the heaters or to determine how many heater supplies you actually need.
FE: Generally, you don't have to regulate power tube heaters; noise is usually not an issue and when it is, it's almost always common mode, which takes a different means to prevent. The exception is direct-coupled circuits, where any drift of output tubes off their nominal operating points can fry something.
Old 23rd March 2007, 10:48 AM   #9
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Just use a common mode choke.
Regulated Heater test supply ThSpeakerDude88 Power Supplies 3 5th December 2007 09:40 PM
Heater reference Nixie Tubes / Valves 3 2nd July 2006 03:58 AM
regulated DC heater supply jarthel Tubes / Valves 30 29th May 2006 12:19 AM
Regulated Heater Supply Kashmire Tubes / Valves 6 4th January 2004 02:23 AM
Page generated in 0.08894 seconds (81.55% PHP - 18.45% MySQL) with 10 queries
