diyAudio Sponsor
Old 22nd March 2007, 11:19 AM   #1
ianc13 is offline ianc13  United Kingdom
Default 4V Tentlabs filament supply
I have a quick question about wiring up a Tentlabs filament supply.
The supply is 4V and looking on the Tentlabs page for fitting instructions it seems that 'ground' side of the supply should be connected to the top of the cathode resistor for auto bias.
Would I need to look at biasing my output tube slightly differently in this instance - i.e. shifting the bias by 2V so that the filament is bias(-31V) + 2V at one end and bias - 2V at the other end.
This is on a Chinese PX25 which should be biased at around -31V for 400V/62.5mA operation.
Thanks,
Ian
Old 22nd March 2007, 03:53 PM   #2
pmillett's Avatar
Technically, yes, it will shift the bias. But +/-2V on a 31V bias point is inconsequential; the tube characteristics will vary more than that. So you really don't need to change anything.
Pete
Old 22nd March 2007, 08:02 PM   #3
Many thanks Pete, most appreciated.
Tentlabs DHT Filament Supplies damohpi Swap Meet 1 12th March 2008 05:27 AM
Parallel vs. series filament supply - or another filament idea engels Tubes / Valves 11 13th May 2007 01:06 PM
filament supply: batteries v TentLabs? rick57 Tubes / Valves 24 10th September 2006 10:56 AM
Selling Tentlabs XO Supply Ruach Swap Meet 0 3rd July 2006 06:56 AM
Need help with Tentlabs power supply gy21 Digital Source 6 23rd April 2006 09:17 AM
Page generated in 0.07796 seconds (70.99% PHP - 29.01% MySQL) with 10 queries
