Plug them into a tube tester, and compare them to a known tube. This should get you "in the ballpark", anyway. This should be helpful if you know that you are only dealing with ECC81, 82, and 83s. If you are not sure that the tubes in question are in this group, then your problem becomes more complicated. There are dealers and other experts that are good at identifying tubes by their internal structure, but I wouldn't think that your chances of finding such a person in Cairo would be very good.
