diyAudio Sponsor
Old 20th March 2007, 02:48 AM   #1
Default 12AX7, 12AU7 Substitution
How can I use 12AX7's instead of 12AU7's?
Old 20th March 2007, 03:08 AM   #2
SY's Avatar
To do what?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 20th March 2007, 06:48 AM   #3
To use them in both input & driver stages.
You see I've got tons of ECC83's & no ECC82's
By the way do you know of any schematics which uses ECC83's in both stages?
Thanx
Old 20th March 2007, 08:47 AM   #4
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
You can't. They are entirely different valves. Don't fret about not having any ECC82, it's not a very good valve. The most expensive substitute for an ECC82 is the 6SN7, but an even better (and usually one quarter of the price) substitute is 14N7. Obviously, neither of these are plug-in substitutes but if you're at the design stage, going for 12V heaters and bigger valves is no problem at all.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 20th March 2007, 11:42 AM   #5
d2134 is offline d2134  Romania
Send a message via Yahoo to d2134
You can use ECC83 to drive small tubes like EL84.
http://ecclab.com/schem/ecc06/110102/wzmra008.jpg
http://www.jerrycb.wz.cz/schemata/nfzs21.gif
Old 20th March 2007, 12:15 PM   #6
I've got 120 ECC83's !!!. I have to do something with them so here is another question:
Can I use ECC83's Instead of ECC81's or the 12BH7's in this schematic?
http://www.bonavolta.ch/hobby/en/audio/6l6_4.htm
If yes: What changes do I have to make to resistor values etc.?
Please HELP me
Thanx
Old 20th March 2007, 12:25 PM   #7
SY's Avatar
No, that position is not suitable for ECC83. The ECC83 is a low current, high mu tube. The 12BH7 is a high current, low mu tube.
Is that schematic really a published design? My goodness.
Old 20th March 2007, 01:15 PM   #8
Ok,
Any body knows of a schematic that uses ECC83's with 6L6's??
Please!
Old 20th March 2007, 01:35 PM   #9
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Sell them on eBay, if they are wanted NOS maybe you can get $$$. Are they JAN, mixed, or single branded? European probably? Guitarists are pursuing good NOS ECC83/12AX7.
Old 20th March 2007, 04:32 PM   #10
kevinkr's Avatar
Hi Sy,
That design came out of Rainer Zur Linde's "Build Your Own Audio Valve Amplifier" book.. There are some quite interesting global feedback pre-amp circuits in that book with tone, balance, and volume controls inside the feedback loop.. I have the book, I guess originally translated from German. I bought the book at a time when I was curious about what other people were doing, and had no intention of building the designs presented. Indeed I never do, have to reinvent the wheel as you already know, that's at least half the fun of this hobby..
To Valvomaniac,
I'm with Salas on this one, sell about 2/3 of them on eBay.. Depending on what they are they may be quite popular with guitarists or owners of vintage hifi..
Instead I would purchase some 12BH7A, 6FQ7, D3A, 5842, 6SN7 - all are far better sounding than the typical 12AU7A.. There are a few good 12AU7A made by the likes of Amperex Holland or Germany, Philips Miniwatt E82CC, Mullard, Valvo, and Mazda. All of these are quite a bit better than the garden variety GE, Sylvania or RCA 12AU7A. I like the Amperex a lot and the Mazda are particularly nice sounding and are surprisingly linear too. (I used them in an srpp line stage which had <0.05% thd at 5Vrms out on a 280V supply, not bad at all..) All of these are likely to be expensive, but perhaps if you hunt around Cairo you might find some..
www.kta-hifi.net
Trade: 2- 12au7's for 2-12ax7's New Production mrdon Swap Meet 0 16th August 2006 11:06 AM
Major diff between 12AX7 and 12AU7 24kilo Tubes / Valves 32 3rd May 2006 01:42 AM
12AU7 or 12AT7 instead of 12AX7 ? Gubby Tubes / Valves 5 25th June 2004 11:31 PM
OTL Headphoneamplifier with 12AU7 or 12AX7 Mr. Triatic Tubes / Valves 7 25th March 2003 04:26 PM
Page generated in 0.10341 seconds (81.21% PHP - 18.79% MySQL) with 10 queries
