Quicksilver Tranny Question - diyAudio
Old 13th January 2003, 08:25 PM   #1
wheezer is offline wheezer  United States
Default Quicksilver Tranny Question
I'm looking for feedback on how warm/hot/very hot either tranny gets on any QS models?
Mitch
Old 13th January 2003, 08:49 PM   #2
I have a quad of quicksilver 8417s and a GLA. The transformers get warn but not bad at all. Both the 8417 and the GLA have about the same temp on the output and power tranformer. Warm to the touch, you could touch them all day when playing them and not have to pull you hand away.
Old 13th January 2003, 08:55 PM   #3
I recently redesigned my PSU and the darn mains tranny gets very hot, almost to where ya don't want to touch it. If sitting idle, it cooks pretty fast.
I think I might have moved it from AB at idle into A?
The OP tranny was getting hot, which was due to long speaker cables-- not a good idea for any tube amp. A ZOBEL took care of that,but really need to cut the length of the cable down.
Thanks BillyBeer
Old 13th January 2003, 11:36 PM   #4
diyAudio Senior Member
fdegrove's Avatar
Default CLASS A
This is not normal.I suspect you're amp is leaking current somewhere.
Some xformers can get hot and be happy with this but NOT the OPT though.
Check your circuit.Check your caps for leakage.
Frank
Old 14th January 2003, 01:29 AM   #5
The OPT is ok- now, as the zobel took care of it. Barely gets warm.
I'ts the mains trafo that gets very hot.
Tranny question Brit01 Tubes / Valves 10 30th July 2009 09:42 PM
Tranny capability question... 69CamaroSS396 Power Supplies 0 9th May 2009 05:00 PM
Quicksilver 8417 question john65b Tubes / Valves 1 24th October 2008 07:40 PM
Another Tranny Question bcrescen Chip Amps 7 26th September 2006 04:42 AM
Tranny question keps Chip Amps 8 23rd September 2006 11:56 PM
Copyright 1999-2017 diyAudio
