diyAudio Sponsor
Old 19th March 2007, 08:01 AM   #1
Default Setup & Implementation of G Pimm's Self-Bias CCS
A while back somebody posted on this forum how they setup and implemented G. Pimm's self bias CCS in their circuit.
How to choose resistance values, etc. I think they posted that they started with a 22K resistor and went from there.
Could somebody post me a quick link to that, if possible. I've been looking with no luck.
Thanks, Daniel
Old 19th March 2007, 06:30 PM   #2
kopite is offline kopite  New Zealand
If you build it exactly to Gary's design the reference voltage is 14v. (approx)
Use this voltage divided by the current to select R1.
If the current you want is 20mA then use a 680 ohm.
Adjust the pot to give you a 13.6v drop across the 680 Ohm.
Old 19th March 2007, 08:33 PM   #3
jeapel is offline jeapel  Canada
hi
for my 6sn7 preamp test at 5ma bias :
1- c4s ccs like bottlehead
2-self bias normal ccs and mu-follower output
G.P. normal ccs is good one and mu-follower give
very good bandwidth because low zout to attack
next stage
but to my ears and only to me :-) i prefer the sound
of c4s ccs it s more soft sound
bye
Old 20th March 2007, 11:50 AM   #4
@ 5ma no heatsink on 2n2907 but small heatsink on mje350
Old 20th March 2007, 02:09 PM   #5
Brian Beck's Avatar
Sorry if I sound like a broken record here:
Pimm’s CCSs were an improvement over other kinds of CCS designs since he was able to greatly reduce shunt capacitance. His tests showed only 0.08pF of shunt C in his self-bias design, and even lower in some of his more elaborate designs. The C4S (as I understand it) and other simple cascoded variants expose the load to the full Ccb of the bottom PNP, here an MJE350. This transistor’s base is shunted to ground at high frequencies by the capacitors (and sometimes LEDs) in the divider path to B+, which is itself shunted to ground via filter caps. So Ccb is shunted to ground by this path, and it directly loads the plate. My MJE350 data sheets don’t specify Ccb, but it will be a lot higher than 0.08pF and it will be variable with collector voltage for sure, the real problem. I think that capacitance modulation is one the main reasons why CCSs can sound so different from one another, even when the capacitances create RC time constants that would suggest no effect within the audio band. Just my opinion…
Brian
Old 20th March 2007, 10:14 PM   #6
hi Brian
my frequency test give : 6sn7 with ccs + 6as7 cathode follower
fc -3db = 90Khz with c4s
fc -3db = 110Khz with G.P. ccs
lower shunt capacitance for G.P. but not so bad for c4s
like you say the sound signature is intriguing from
ccs to another
Old 20th March 2007, 10:44 PM   #7
Brian Beck's Avatar
jeapel,
That's good data, and decent performance. I think you're seeing the effect of additional capacitance that exceeds the CCS capacitance, such as inter-element capacitances, stray capacitances and the input capacitance of the 6AS7 cathode follower. Your source impedance matters greatly too. That's OK because these other capacitances are usually not as non-linear as the smaller CCS shunt capacitances (although they might be microphonic). Even when these other sources of capacitance are present, a smaller, but modulated, capacitance can have an imprint on phase shift behavior, IMO.
Brian
Old 21st March 2007, 12:00 AM   #8
ok 6as7 input cap explain the test result
"CCS shunt capacitances (although they might be microphonic)"
maybe it s my situation because my tube preamp sound is
very good but microphonic just a small finger tap is on
speaker
how a "transistor" shunt cap can be microphonic ?
Old 21st March 2007, 12:07 AM   #9
Brian Beck's Avatar
I wasn't including the transistor capacitance in my comment about microphonics. Transistors can be slightly microphonic, but usually much less so than a tube.
Brian
Old 21st March 2007, 12:18 AM   #10
sorry Brian my english is so so
if i understand a 6sn7 ccs load (very hight AC resistor) is
no more microphonic than 6sn7 with 47kohm load or
i m wrong
Gary Pimm self bias CCS but without LND150 bigwill Solid State 1 12th January 2009 05:04 PM
Wanted: PIMM Self-bias CCS boards riotubes Parts 1 16th January 2008 02:37 PM
My implementation of the Audidigit T-amp Mick_F Class D 9 3rd October 2005 08:50 PM
bias setup Forte 3 Arroyo Solid State 1 23rd June 2005 09:54 PM
mr. pimm's ccs rev.3? sparkle Tubes / Valves 9 25th August 2004 06:40 AM
Page generated in 0.11176 seconds (80.30% PHP - 19.70% MySQL) with 11 queries
