diyAudio Sponsor
Old 19th March 2007, 12:14 AM   #1
Default Tube Preamp FM interference
Has anyone experienced local FM radio stations interferring with you tube preamp. I tied a friends preamp and as soon as i powered up I got the local radio station bright and clear throught the preamp. There was no tuner hooked up just to make thing clear. I wanted to purchase or build a tube preamp and wonder if this problem will go away with other designs or will i have a problem due to the close proximity of the local transmitter tower. I think it is about 3 moles away. Any thoughts or suggestions
Old 19th March 2007, 01:43 AM   #2
Geek's Avatar
Not FM, but an AM station.
I added a 100uH inductor in series with the grid snubber and played with some low value ceramics to ground until it went away.
Increasing the grid snubber resistor can help too and let Miller C form the RF killing filter.
Cheers!
Old 19th March 2007, 02:48 AM   #3
gofar99 is offline gofar99  United States
Greetings, I have not had this happen recently, but the advice is sound. Another possibility is that it is getting through the power cord. A snap on ferrite will generall fix that. BTW, the process involved when an amp picks up the RF signal is ofter referred to as grid rectification. The grid and cathode can act much like a diode and "detect" and amplify the rf. Usually it is AM but stong FM and TV stations can cause the problem too. It became common many moons ago when the stations became more numerous and powerful and the amp designers didn't keep up. SS equipment can also do this, but perhaps because of design changes over the years, it doesn't seem as common.
Good listening
gofar99
Old 19th March 2007, 10:32 PM   #4
Default PReamp FM interfrences
Thanks for the information. I was hoping there was an easier solution. I would hate to buy a manufactured unit and find i have to disect it.
Old 20th March 2007, 01:21 AM   #5
Default WHere is the interference coming from
Can someone tell me where the interfence is induceded into a preamp. Is it directly into the drive tube or some other place such as cables. I need someone to identify where this is coming from and why. THanks
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 04:14 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
tube preamp using submini tube unclejed613 Tubes / Valves 11 19th August 2007 07:14 PM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 05:28 PM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
Page generated in 0.07381 seconds (80.80% PHP - 19.20% MySQL) with 10 queries
