diyAudio Sponsor
Old 18th March 2007, 02:20 PM   #1
Default EL 84 Pentode Config.
EL 84 Pentode configuration.
Sound sweet and nice. Except 2 drawback.
Slow no speed .
Bass sound bloated.
Any suggestion .
etl
Old 18th March 2007, 03:15 PM   #2
I have questions.
Do you have a schematic?
Is it se or pp?
Old 18th March 2007, 03:21 PM   #3
Tube_Dude's Avatar
Default Re: EL 84 Pentode Config.
Slow no speed .
Bass sound bloated.
Any suggestion .
Have you used negative feedback?
Jorge
Old 18th March 2007, 04:07 PM   #4
SY's Avatar
No NFB = High output Z. High output Z = Big, bloaty bass with speakers not specifically designed for that. And a frequency response that looks like a roller coaster.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 19th March 2007, 02:48 PM   #5
Default EL 84 slow NOW Fast.
Found out the problem with the pacing.
Over size supply cable , changed to copper tin type.
Bass still bloated.
Schematic : www. Diyparadise.com/buildel84c.html
It's PP.
etl
Old 19th March 2007, 03:31 PM   #6
ilimzn is offline ilimzn  Croatia
Why ask questions, if you don't bother to read answers?
Old 19th March 2007, 04:24 PM   #7
phn is offline phn  Sweden
phn's Avatar
Scrap the UL. Try connect the screens directly to B+.
Old 19th March 2007, 04:39 PM   #8
Default UL / Screen B+
Still no good.
etl
Old 19th March 2007, 04:57 PM   #9
dshortt9's Avatar
If you have 4,8, and 16 ohm output taps you could use them to apply cathode feedback to the EL84's like Audio Research does. This would tighten up the base.
Old 19th March 2007, 05:58 PM   #10
phn's Avatar
Try triode connect the EL84s. 100 Ohm resistor between screen and anode.
This will reduce gain. But it's a start. If this works you might have to use feedback if you want to run the amp in UL or as pentode. Triodes have internal NFB. Pentodes don't.
Need some help on speaker config pityocamptes Car Audio 11 4th October 2007 12:59 AM
831882 in an MTM config? weinstro Multi-Way 2 24th September 2007 04:02 PM
Bridge amp config comparison panson_hk Solid State 13 2nd September 2007 10:32 PM
A small no-fuss pentode/pentode SE amp Tubes4e4 Tubes / Valves 13 1st January 2006 05:16 AM
need help on my config hacknet Solid State 14 2nd December 2002 03:43 PM
Page generated in 0.09202 seconds (76.34% PHP - 23.66% MySQL) with 10 queries
