diyAudio Sponsor
Old 18th March 2007, 01:41 PM   #1
willyhoho's Avatar
Default Amp Tubes
I have been looking for a tube amp 20w to power my electrostatics. Being
a high imp load. What type of tube amp should I be looking for? I would think it should be a push-pull type or am I off base. Is there a basic tube type (12ax7, 6gw8 etc.) and how many tubes,transformers
should there be? Can someone provide a schematic,site or model# I can look at. Thanks to all,I do love this forum. Willy
Old 18th March 2007, 02:09 PM   #2
diesel_tech's Avatar
Send a message via MSN to diesel_tech
What you should be looking fo is all up to you, single ended (SE), push pull (p-p), ultralinear (ul) tetrode or pentode. Its all up to what sound you like. Tubes are the same way, 2A3's are good, sound like they have decent bass and are a triode. 6L6's, KT88's,, are pentodes, and used quite regularly in higher watage amps, and supposedly sound good there are tons of tube that are used. Best thing to do is search this site and read the post of others about tubes and their sounds, and schematics, there are many to choose from.
Jeremy
Old 18th March 2007, 02:24 PM   #3
phn is offline phn  Sweden
phn's Avatar
For 20W I say PP. An output transformer suitable for 20W SE is huge and expensive.
Go to google image search and type EL34, 6CA7, 6L6, 6L6G and KT88.
After that, come back and ask.
Old 18th March 2007, 02:33 PM   #4
Do like the rest of us and start buying tube amps and sell the ones you don't like.... You can't say triode is better than pentode, etc. Each amp has it's own plus points and minus points.... Actually can you borrow some amps for starters??
The stuff you don't know always humbles us.........
Old 18th March 2007, 04:42 PM   #5
rdf is offline rdf  Canada
rdf's Avatar
Default Re: Amp Tubes
Originally posted by willyhoho: Being a high imp load.
Are you sure? I've seen electrostat measurements, Martin Logan comes to mind, in which the impedance tanks at high frequencies to under two ohms. That's a tough slog for normal tube amps and near impossible for one without feedback. Personally I'ld start at a push-pull (you need the power), triode (all else equal the lowest output impedance) amp with feedback (likely no choice.)
Tube Noob! need help with tubes lots of tubes therapy_fan Tubes / Valves 15 29th January 2009 09:01 PM
WTT: Various tubes for 6CA4/EZ81 rectifier tubes GordonW Swap Meet 4 27th August 2008 12:37 AM
Tubes! Geek Swap Meet 4 16th May 2008 06:20 PM
CV428 tubes (Loktal 807) tubes FS mobyd Swap Meet 3 2nd January 2008 11:26 AM
many new tubes and tubes meter for sale elviukai Swap Meet 4 30th October 2003 09:22 AM
Page generated in 0.08661 seconds (72.78% PHP - 27.22% MySQL) with 10 queries
