| diyAudio Sponsor | ||
I was browsing sowter and have seen the word several times in the site.
thanks for the reply. |
#2 |
One that doesn't know the lyrics?
I'll be here all week.. try the veal. |
#3 |
It's a copper band wound around the outside of the core and windings. It acts as a shorted turn to leakage flux, helping to contain it.
On a power transformer it can help lower radiated noise (like diode recovery spikes) from getting into other curcuits. Pete |
#4 |
Mark Knopfler wore a luminous one tied over his brow for the "Money for nothing" video.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#5 | ||
Magneto the Gravity Man
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#6 |
Touche!
#7 | |
thank you |
| Tang Band W3-593SF vs. Tang Band W3-926SD | Zaputh | Full Range | 17 | 5th June 2009 11:37 PM |
| Sub for band use | ScottC | Subwoofers | 7 | 9th October 2008 12:15 PM |
| HiFi Ham band AM?? | GK | The Lounge | 8 | 19th May 2008 11:12 AM |
| Tang Band MTM ? | wrenchone | Multi-Way | 11 | 21st November 2007 06:39 PM |
| a band called Ra | Shpoop | Music | 3 | 7th July 2005 11:29 AM |
| Page generated in 0.08752 seconds (85.22% PHP - 14.78% MySQL) with 10 queries |
