diyAudio Sponsor
Old 17th March 2007, 03:56 PM   #1
pawcio is offline pawcio  Poland
Default AN Conquest Clone modification
Hi all!
I've built my tube amp based on schematic of AN Conquest.
Yesterday I made a modification suggested by a friend.
I removed C and R form the first cathode of 6SN7 and put there a 2,4V battery
I was a little afraid but everything's o.k.
amp didn't blow and sounds a little bit hmmm smoth and airy.
but I consider if it is safe fo amplifier? what with charging this NiCd battery? will it be charge by current (about 5mA)?
Old 18th March 2007, 09:12 AM   #2
hmm .... nobody?
photo:
Old 18th March 2007, 12:29 PM   #3
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
Thaaaaat's fine! I like batteries and leds. 5mA is a charging current that a 300mah battery can easily handle so it should be fine there.
Ciao
Gianluca
Old 18th March 2007, 09:11 PM   #4
Jozef is offline Jozef  Poland
Pawcio,
This battery maybe give you a little too high bias.
Try to found 1.2V single cell NiCad.
Jozef
Old 19th March 2007, 08:20 PM   #5
what kind of led would you suggest? (color?)
This battery maybe give you a little too high bias.Try to found 1.2V single cell NiCad.
1,2V? Isn't it too low?
normally I had about 2V on cathode resistor (320R)
Citronic Conquest V12 scheme kvangelo Solid State 18 20th January 2012 08:29 AM
Conquest 1200 amp mickb Solid State 7 22nd June 2009 09:58 PM
Audio Note Conquest? EsE Tubes / Valves 4 22nd May 2006 11:46 PM
Audionote Conquest PCB Layout hifi Tubes / Valves 2 1st August 2003 10:04 PM
Page generated in 0.08130 seconds (70.08% PHP - 29.92% MySQL) with 11 queries
