| diyAudio Sponsor | ||
seems very few of them. I've search the forums and have come across thorsten's one, the sun audio 300B PP.
thanks for the replies |
#2 |
Here is a sample of a 842VHD PPP.
![]() ![]() Photo Gallery http://www.veiset.net/842/ Just some minor modifications (lower B+) and it can run with 300B. Jan E Veiset
Life is hard - Then you die. |
#3 |
pls considerate this, very very good sound.
Žg—p^‹óŠÇECC84, E180CC, 5AR4, 300B ƒ_ƒ“ƒsƒ“ƒOƒtƒ@ƒNƒ^[4.5 (8ƒ¶ 1kHz +10dBV)ƒgƒ‰ƒ“ƒXAP-3001, A-4003, F-2021•‰‰×ƒCƒ“ƒs[ƒ_ƒ“ƒX0, 4, 8, 16ƒ¶Œ‹‡•ûŽ®C,RŒ‹‡ (ƒ€ƒ‰[ƒhŒ^) Á”ï“d—Í210VA (100V, 2.1A, 0M†Žž) Å‘åo—Í17W~2 (8ƒ¶ 1kHz)ƒVƒƒ[ƒVƒOƒ‰ƒtƒ@ƒCƒgF“h‘•AƒTƒuƒpƒlƒ‹•t“ü—ÍŠ´“x0.8V (8ƒ¶ 1kHz Å‘åo—ÍŽž)¡–@430(W)~240(D)~220(H) Žü”g”“Á«4Hz`90kHz (-1dB 1WŽž) Š®¬d—Ê 21.6kg •‰‹AŠÒ—Ê 8dB (8ƒ¶ 1kHz)‚’²”g˜c—¦ 0.2% ˆÈ‰º (8ƒ¶ 1kHz 1W) ECC84, E180CC(MULLARD),5AR4 •W€‘•”õŽc—¯ŽG‰¹1.0mV ˆÈ‰º (8ƒ¶ •‰‰×Žž)ƒNƒƒXƒg[ƒN@-76dB (10kHz LÌR) 300B•Ê”„ thx thomas
#4 |
#5 |
It says that 300B is possible .... but how ???
http://www.pmillett.com/push-pull_kt...driver_pcb.htm |
#6 |
Another one you could look at:
http://www.audiodesignguide.com/my/pse2.html That is version 2, the version 1 has some different options for the PSU for either Stereo or Mono block configuration. http://www.audiodesignguide.com/my/pse.html I believe that this was published in the Glass Audio Projects book some time ago. |
#7 |
300B pushpull design article I wrote that was published in VTV in collaboration with Svetlana (they gave me sample 300B tubes to evaluate) back around 1999.. Link is on my site under amplifier projects.
www.kta-hifi.net |
#8 |
The http://www.audiodesignguide.com/my/pse2.html gets my vote, except PP.
That is, use the 417A or, better, 437A and a trafo phase splitter. The 437A is insane, performance (800 Ohms Rp and mu of +40) and price wise. But if you spend this kind of money, you can just as well spend another small fortune on the drivers. |
#9 | |
thank you |
#10 | |
any comment on the amp compared to your other amps? thank you |
| TI Samples | ctardi | Parts | 22 | 12th May 2010 07:41 PM |
| FS: for 300B (JE Labs 300B SE) builders | cartman | Swap Meet | 2 | 29th October 2008 01:13 PM |
| Samples | jkeny | Everything Else | 2 | 30th August 2006 02:38 PM |
| * 35 watt * 300B SE = super 300B + Class A2 | rick57 | Tubes / Valves | 4 | 13th July 2005 04:18 PM |
| Page generated in 0.10599 seconds (80.14% PHP - 19.86% MySQL) with 10 queries |
