diyAudio Sponsor
Old 16th March 2007, 05:07 AM   #1
jarthel is offline jarthel  Australia
Default power supply choke with a connection for AC ground?
I bought a choke and it has a 3rd wire for the AC ground. this wire is not connected to any of the other 2 wires.
should I connect this to ground? does it have any positive effect?
thank you.
Old 16th March 2007, 05:10 AM   #2
leadbelly's Avatar
Default Re: power supply choke with a connection for AC ground?
Yes, just as you would/should chassis ground any power transformer.
Potential life extension
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 16th March 2007, 05:55 AM   #3
thank you
Old 16th March 2007, 06:49 AM   #4
senderj is offline senderj  Hong Kong
If my choke does not have one, is it possible to make one myself? From the metal surface of the choke to AC ground or psu ground?
Old 16th March 2007, 10:10 PM   #5
leadbelly's Avatar
Yes, the metal of the choke should be grounded. If mounting to a metal plate, I don't bother with a separate wire, I just make sure that there is metal-metal contact (not painted-metal-to-metal contact). If there is some reason why that can't be done, I just make a bonding wire with a washer style connector on the end so that the mounting screws will hold the wire to the metal.
How to do the best of connection in multi-CAP power supply ckwong99 Solid State 22 30th July 2009 11:50 AM
choke for the power supply jarthel Pass Labs 44 2nd July 2007 10:23 AM
choke for an 8v power supply jarthel Parts 0 9th May 2007 02:12 AM
DC Choke for power supply senee Power Supplies 8 21st March 2005 09:05 PM
Choke power supply supernet Everything Else 1 12th May 2002 11:33 PM
Page generated in 0.09490 seconds (72.65% PHP - 27.35% MySQL) with 10 queries
