No mains transformer B+ ?
Old 14th March 2007, 10:19 AM   #1
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Default No mains transformer B+ ?
I have a quartet of RCA 6V6G dark glass NOS. Having a 230V AC outlet I wonder if there is something negative into rectifying directly to 300-320VDC and powering some some possible 6V6G amp with it. Transformers help a little with mains grunge also, but apart from that, have you tried it? Is it a good practice not to use a transformer when AC gives compatible voltage to rectify for needed B+ by luck?
Old 14th March 2007, 10:22 AM   #2
phase_accurate is offline phase_accurate
It is only good practice if you don't mind getting killed by your amp !!!
Charles
Old 14th March 2007, 10:25 AM   #3
Salas's Avatar
Elaborate please.
Old 14th March 2007, 10:37 AM   #4
arnoldc is online now arnoldc  Philippines
Send a message via Yahoo to arnoldc
It's all about safety! You would want to isolate your circuit from the mains.
Soon, the safety patrol will gang up on you
Old 14th March 2007, 10:41 AM   #5
Burnedfingers is offline Burnedfingers  United States
If I understand you correctly you want to take your main power AC feed and rectify and filter it to DC without the use of a transformer.
Do you enjoy life? This is very stupid! Never, never, even consider trying something like this!
Old 14th March 2007, 10:44 AM   #6
Salas's Avatar
Can't a 230VAC 1:1 transformer with 0.3A capability kill someone touching a 320V B+ all the same?
Old 14th March 2007, 10:50 AM   #7
From a legal point-of-view there might be quite a difference between being killed or being killed all the same !
If you rectify your mains directly then a wall outlet that is wired the wrong way around is actually all it takes to kill you.
Charles
Old 14th March 2007, 10:54 AM   #8
Salas
Is you life worth the cost of a transformer? If not then I highly suggest that you sell the tubes and anything else associated with building an amplifier.
Old 14th March 2007, 10:55 AM   #9
Salas's Avatar
OK then, I will not do it, bcs if an outlet is wrong there will by no transformer to fry, but the first one who touches the RCA plug. Got it.
Old 14th March 2007, 11:04 AM   #10
Salas's Avatar
Charles
I will get a 230VAC 1:1 toroid, Audio Note 8KPP OPT and make an Audio Tropic musical machine, I am not giving my RCA 6V6Gs to nobody!
No mains transformer B+ ?Hide this!Advertise here!
Using mains transformer as output transformer Elias Tubes / Valves 176 11th March 2013 09:35 PM
Quad 405 mains transformer? Confussed Solid State 2 14th August 2007 06:12 PM
Mains Transformer Question MlinarS Tubes / Valves 10 25th November 2005 02:56 PM
Mains transformer orientation Rocky Tubes / Valves 20 23rd November 2005 10:52 AM
Question on Mains Transformer MlinarS Tubes / Valves 1 1st March 2005 11:57 AM
Copyright ©1999-2017 diyAudio
