diyAudio Sponsor
Old 14th March 2007, 10:36 AM   #1
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Default Help with horizontal mounting of 01-A and VR tubes
Guys, I've checked the documents for the 01-A and VR150 tubes and can't find if they can be installed horizontally. While I agree to the glow appeal of these tubes, I found a nice chassis I can use but I'll put the tubes inside and they won't fit vertic ally. I can't even see the innards of my 01-A if I can get the filament planes vertical. Then there's the VR...
Anybody got info on this?
Old 14th March 2007, 05:26 PM   #2
kevinkr is online now kevinkr  United States
kevinkr's Avatar
Yeah, I use small dhts like the 01A, 12, and 26 in my own designs. You need to mount these vertically otherwise over time the filament could possibly sag and make contact with the grid. (You'd think the clearances would be large enough to prevent this, but I've seen at least one 26 that had a filament to grid short.)
All of the antique radios I have seen and the couple I have owned always had dhts in a vertical orientation.
My old data books (Cunningham, RCA, etc.) recommend vertical mounting for all dhts - this also applies incidentally to some early dh rectifiers (and all domestic use mercury types I'm familiar with) as well.
VR tubes don't have this issue and afaik they can be operated in any position as long as ventilation is adequate
www.kta-hifi.net
Old 15th March 2007, 12:32 AM   #3
Sigh, thanks so much Kevin. Highly appreciated.
It's now back to top plate style chassis for this project then.
But then the Fi...
Thoughts on horizontal sweep tubes? DaveCan Tubes / Valves 14 28th August 2008 10:24 PM
Horizontal mounting of large capacitors bitnissen Parts 2 26th April 2008 02:21 PM
Horizontal TV tubes used in amplifier? MGH Tubes / Valves 40 1st April 2007 08:33 PM
Tubes operating in horizontal position G.Cesar Tubes / Valves 10 24th May 2005 07:35 AM
Orientation and Horizontal Mounting SY Tubes / Valves 31 2nd April 2004 09:08 AM
Page generated in 0.07071 seconds (73.22% PHP - 26.78% MySQL) with 10 queries
