Fixed-Bias Williamson EL34
Allow me to suggest a "safe" bias circuitry.
Called so, cos if a pot cursor lift off, tubes just become over biased ;)
Yves.
I'm pretty sure it's cap input. The link you posted says:
"H.V. DC current below, measured with cap. input filter, full wave (two diode) C.T., rectifier circuit"
According to a PDF elsewhere on the Hammond website, choke input should give .45 * the secondary VAC, so 450V out of 1000VCT, and 1.54 * the current rating, so 308mA. Encouraging numbers.
  • hammond choke vs. cap input.pdf
Hey Yves, a couple questions if you don't mind :smash:
My bias is -45V, and supply is -70V or so. So I have 17.2K on the top top resistors, 10K below, 100K to the grids, and 1uF for a 15Hz response. I should probably know this, but what range of adjustment will your setup give me?
Here's my not-so-foolproof math: I assumed the upper pot to be halfway across, so I could replace the top 2 resistors and the 10K pot with a single 11.1K resistor (17.2+5)/2, making a simple voltage divider. In that case, the bottom pot should adjust the total output voltage between -33 and -45V right? I would rather be able to adjust to around -10+15V of -45V (keeping signs constant), since that's the central point of my schematic... Is something wrong with my math, or should I try some different resistors to suit my goals?
