diyAudio Sponsor
Old 13th March 2007, 07:05 PM   #1
Default Bogen CHB-35 Preamp Mod
Some time ago, I acquired a Bogen CHB35 for modification into a guitar amp. I am FINALLY ready to start it. However, I had a few questions to ask before proceeding.
I would like to leave one channel stock and modify the first stage of the second channel. The schematics for the original and my proposed mod are below. First, I need to know the voltage to put on the plate resistor of the modded stage. Second, I need to know the value of the new resistor in the power supply. I have added a stage to the power supply for the modded preamp stage. Any comments on that?
Also, I'm worried that the new preamp stage would be "too much." Any thoughts? Would a resistor in the signal path help, and if so, what value? Also, would a 470k resistor to ground at the junction of the 470pf cap and 470k resistor help? I got this idea off the AX84 High Octane, which has this extra resistor in place (schematic below - first stage only). I assume it acts as a voltage divider?
Any help is greatly appreciated.
Original schematic
http://i18.tinypic.com/2ce6drq.jpg
Modified Schematic (in progress)
http://i16.tinypic.com/2yyo7jr.jpg
AX84 HO first stage preamp
http://i17.tinypic.com/30k3pjo.jpg
bogen amp karma Tubes / Valves 15 16th August 2011 10:45 PM
Searching schematic for Bogen sound system LOL tube preamp Lily Instruments and Amps 3 10th January 2007 09:38 PM
Bogen CHB35 Mods and Preamp ideas gtrbryan Tubes / Valves 1 25th September 2006 11:52 PM
Bogen amp bobhedberg Tubes / Valves 1 20th May 2006 09:29 PM
Help with bogen CH8 imix500 Tubes / Valves 6 28th April 2006 03:49 AM
Page generated in 0.06301 seconds (71.31% PHP - 28.69% MySQL) with 10 queries
