modifications to compact EL84 amp
Old 14th January 2003, 09:09 PM   #21
Joel is offline Joel  United States
Joel's Avatar
Default Re: CONSERVATIVES.
Originally posted by fdegrove
If you value awesome dynamic range and deep,solid bass...follow my lead.
Be careful Frank - you're implying that frequency response of an amplifier is determined by power supply capacitance - which is not true really.
There is no need for larger than a 100uF cap in any tube amp.
Old 14th January 2003, 09:14 PM   #22
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default I KNOW WHAT I'M DOING.
It's not frequency response as it is statically measured but sustained bass tones from a complex musical signal.
AKA perceived dynamic range, AKA headroom.
This is especially true for Class AB amps (most oldies are) and won't do any harm to a Class A amp either.
Think dynamic,think music,
Frank
Old 15th January 2003, 04:02 AM   #23
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: elegance
Originally posted by Jaap
]perhaps this has still some more elegance:
I have something similar in the queue using an Edcor (budget) tranny as phase splitter on the input (don't know how much DC it will take) and a pr of drivers after into EL84s (or a pr of ECL 82, or 86). Iron from an old Normende.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th January 2003, 08:46 AM   #24
Brett is offline Brett
Brett's Avatar
Originally posted by analog_sa
Don't want to sound negative but i've tried liberating EL84 pentode amps from negative feedback and the results have been quite lo-fi. Anyone been luckier?
cheers
peter
Agreed. The EL84, which can be a really sweet tube is best in NFB UL applications like the ST35/SCA35 or even better as a class A PP triode, if you can deal with the 3W it puts out.
Old 15th January 2003, 08:53 AM   #25
Brett's Avatar
Jaap,
Phase split before the driver and run the driver PP. Works much better to my ears.
There's been a long thread here about a similar circuit in the past (Ralph poweramp). Also check the writings of Lynn Olson at his site ( www.aloha-audio.com ) as well as the archives at audioasylum under his name, and Garry Dahl (gdahl) who was the designer of the Ralph poweramp. There is tons of valuable info there, as they are both very experienced, and measure everything as well as listen to tune the circuits.
Old 15th January 2003, 06:52 PM   #26
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Thumbs up thanks for the suggestions
modifications to compact EL84 ampHide this!Advertise here!
5W EL84 drive EL84 SE Audio_idiot Tubes / Valves 31 31st May 2012 08:38 PM
NHT 3.3 Modifications SY Multi-Way 22 22nd June 2008 05:12 AM
DAC-in-the-Box modifications. Again. Aleksunder Digital Source 1 19th July 2007 03:10 AM
DAC modifications elaar Parts 5 29th May 2006 01:11 PM
Zen V4 modifications pro Pass Labs 2 31st August 2004 05:19 PM
